Here's the output I get from the Arduino IDE when I try to program the flash memory on the ATmega32U4. Any help getting this to work would be much appreciated:
[Edit - moderator - use "code" button when submitting large blocks of code or text output]
- Code: Select all
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy -I/Users/btayan/Documents/Arduino/libraries/LPD8806 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SPI /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LEDbeltKit.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LEDbeltKit.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy -I/Users/btayan/Documents/Arduino/libraries/LPD8806 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SPI -I/Users/btayan/Documents/Arduino/libraries/LPD8806/utility /Users/btayan/Documents/Arduino/libraries/LPD8806/LPD8806.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LPD8806/LPD8806.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy -I/Users/btayan/Documents/Arduino/libraries/LPD8806 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SPI -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SPI/utility /Applications/Arduino.app/Contents/Resources/Java/libraries/SPI/SPI.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/SPI/SPI.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=834146814 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/malloc.c -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/malloc.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=496051815 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/pins_teensy.c -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/pins_teensy.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=-banned -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/usb.c -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/usb.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=692073624 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/WInterrupts.c -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/WInterrupts.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -MMD -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DSERIALNUM=-1307195645 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/wiring.c -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/wiring.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/HardwareSerial.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/HardwareSerial.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/main.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/main.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/Print.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/Print.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/Tone.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/Tone.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/usb_api.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/usb_api.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/WMath.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/WMath.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -MMD -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=21 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy/WString.cpp -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/WString.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/malloc.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/pins_teensy.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/usb.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/WInterrupts.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/wiring.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/HardwareSerial.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/main.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/Print.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/Tone.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/usb_api.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/WMath.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/WString.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -Os -Wl,--gc-sections,--relax -mmcu=atmega32u4 -o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LEDbeltKit.cpp.elf /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LEDbeltKit.cpp.o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LPD8806/LPD8806.cpp.o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/SPI/SPI.cpp.o /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/core.a -L/var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp -lm
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LEDbeltKit.cpp.elf /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LEDbeltKit.cpp.eep
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LEDbeltKit.cpp.elf /var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LEDbeltKit.cpp.hex
Binary sketch size: 7536 bytes (of a 28672 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P/dev/tty.Bluetooth-PDA-Sync -b57600 -D -Uflash:w:/var/folders/z8/7qvvx6dd3qg986v19c3trj_40000gp/T/build6511042415148627677.tmp/LEDbeltKit.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 9 2007 at 11:20:31
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/btayan/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.Bluetooth-PDA-Sync
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : avr910
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: ser_recv(): programmer is not responding
avrdude: butterfly_recv(): programmer is not responding
