Thermocouple Amplifier MAX31855
Re: Thermocouple Amplifier MAX31855
Postby ribo » Mon Jun 11, 2012 11:44 pm
Are you checking the board in NY with an ice bath and getting the right readings?
I un-commented all the Serial.prints (even the block commented one).
Here is the output after compiling and running:
MAX31855 test
Internal Temp = 1681A50
Internal Temp: 26.31
26.31
C = 16C1A50
0x16C1A50
5B
22.75
F = 16C1A50
0x16C1A50
ribo
Postby adafruit » Tue Jun 12, 2012 9:39 am
we're confused, that looks pretty reasonable - the internal temp is 26C and the measured temp is ~23C
Postby ribo » Thu Jun 14, 2012 12:13 am
yes this a reasonable error for measuring room temperature.
However -3600 deg F for an ice bath?
Did you try to test an ice bath yet?
ribo
Postby adafruit » Thu Jun 14, 2012 8:57 am
We'll try that today - can you post up the full output with hex debugging for an ice bath? We'll compare!
Postby adafruit » Thu Jun 14, 2012 12:10 pm
OK we tried another ice bath and got down to about 4 *C - can you show a log of it cooling down, at what point do you see the big problem?
Postby ribo » Thu Jun 14, 2012 11:50 pm
Here is a cool down from room temp to ice bath and then back to room temp.
I
.12
24.12
C = 1641820
0x1641820
   Internal Temp: 24.12
59
22.25
F = 1681830
0x1681830
   Internal Temp: 24.19
5A
72.50
MAX31855 test
Internal Temp = 1641810
   Internal Temp: 24.06
24.06
C = 1601810
0x1601810
58
22.00
F = 1601810
0x1601810
58
71.60
Internal Temp = 1601820
24.12
C = 1641820
0x1641820
59
22.25
F = 1641820
0x1641820
59
72.05
24.12
C = 1641820
0x1641820
59
22.25
F = 1601820
0x1601820
58
71.60
Internal Temp = 1601830
24.19
C = 1601830
0x1601830
58
22.00
F = 1641830
0x1641830
59
72.05
24.19
C = 1601830
0x1601830
58
22.00
F = 1601830
0x1601830
58
71.60
Internal Temp = 1641830
24.19
C = 1641820
0x1641820
59
22.25
F = 1601820
0x1601820
58
71.60
Internal Temp = 1401830
24.19
C = 13C1830
0x13C1830
4F
19.75
F = 1301830
0x1301830
4C
66.20
Internal Temp = FFAC1830
24.19
C = FFA41830
0xFFA41830
3FE9
-2042.25
F = FFA41830
0xFFA41830
3FE9
-3644.05
Internal Temp = FFA81830
24.19
C = FFA81830
0xFFA81830
3FEA
-2042.50
F = FFA81830
0xFFA81830
3FEA
-3644.50
Internal Temp = FFB81830
24.19
C = FFB81830
0xFFB81830
3FEE
-2043.50
F = FFB81830
0xFFB81830
3FEE
-3646.30
24.19
C = FFAC1830
0xFFAC1830
3FEB
-2042.75
F = FFA81830
0xFFA81830
3FEA
-3644.50
Internal Temp = FFA01830
24.19
C = FFA41830
0xFFA41830
3FE9
-2042.25
F = FFA41830
0xFFA41830
3FE9
-3644.05
24.19
C = FFA41830
0xFFA41830
3FE9
-2042.25
F = FFA01830
0xFFA01830
3FE8
-3643.60
Internal Temp = FF9C1840
   Internal Temp: 24.25
24.25
C = FFA01830
0xFFA01830
3FE8
-2042.00
F = FFA01840
0xFFA01840
3FE8
-3643.60
Internal Temp = FF9C1830
24.19
C = FFA01830
0xFFA01830
3FE8
-2042.00
F = FF9C1830
0xFF9C1830
3FE7
-3643.15
24.19
C = FFA01840
0xFFA01840
3FE8
-2042.00
F = FF9C1830
0xFF9C1830
3FE7
-3643.15
Internal Temp = FF981840
24.25
C = FF9C1830
0xFF9C1830
3FE7
-2041.75
F = FF9C1830
0xFF9C1830
3FE7
-3643.15
Internal Temp = FF981830
24.19
C = FF981830
0xFF981830
3FE6
-2041.50
F = FF9C1840
0xFF9C1840
3FE7
-3643.15
24.19
C = FFA01830
0xFFA01830
3FE8
-2042.00
F = FFA01830
0xFFA01830
3FE8
-3643.60
24.25
C = FF9C1830
0xFF9C1830
3FE7
-2041.75
F = FF9C1840
0xFF9C1840
3FE7
-3643.15
24.25
C = FF981840
0xFF981840
3FE6
-2041.50
F = FF981840
0xFF981840
3FE6
-3642.70
Internal Temp = FF501840
24.25
C = FF481840
0xFF481840
3FD2
-2036.50
F = FF441840
0xFF441840
3FD1
-3633.25
Internal Temp = FF381840
24.25
C = FF381840
0xFF381840
3FCE
-2035.50
F = FF481840
0xFF481840
3FD2
-3633.70
Internal Temp = 2C1840
24.25
C = 341840
0x341840
D
3.25
F = 3C1840
0x3C1840
F
38.75
24.25
C = FF941840
0xFF941840
3FE5
-2041.25
F = FF9C1840
0xFF9C1840
3FE7
-3643.15
Internal Temp = 1101840
24.25
C = 12C1850
0x12C1850
   Internal Temp: 24.31
4B
18.75
F = 1381840
0x1381840
4E
67.10
Internal Temp = BC1840
24.25
C = C01840
0xC01840
30
12.00
F = D01840
0xD01840
34
55.40
Internal Temp = E01840
24.25
C = 1581850
0x1581850
56
21.50
F = 1641840
0x1641840
59
72.05
Internal Temp = 1381850
24.31
C = 1401850
0x1401850
50
20.00
F = 1381840
0x1381840
4E
67.10
Internal Temp = 1501850
24.31
C = 1541840
0x1541840
55
21.25
F = 1541840
0x1541840
55
70.25
Internal Temp = 1641850
24.31
C = 1681850
0x1681850
5A
22.50
F = 16C1850
0x16C1850
5B
72.95
Internal Temp = 1C81850
24.31
C = 1CC1850
0x1CC1850
73
28.75
F = 1CC1850
0x1CC1850
73
83.75
Internal Temp = 1BC1850
24.31
C = 1BC1840
0x1BC1840
6F
27.75
F = 1BC1850
0x1BC1850
6F
81.95
Internal Temp = 1B01850
24.31
C = 1B01850
0x1B01850
6C
27.00
F = 1B01850
0x1B01850
6C
80.60
Int
ribo
Postby adafruit » Fri Jun 15, 2012 11:46 am
OK thanks, that was the information we needed to fix the problem
download the library, completely delete the old version and try now
thanks!
Postby ribo » Sat Jun 16, 2012 12:05 pm
Thanks -- working much better with the latest library.
ribo
Postby petespaco » Tue Jun 19, 2012 9:09 am
Aren't you folks a little nervous about using the crimped spade lugs that are on the end of those thermocouples? Aren't you creating another separate cold junction? And, aren't you introducing another source for noise, etc.?
petespaco
Postby amconcepts » Tue Jul 03, 2012 2:23 pm
Hey so I just got my MAX31855 and downloaded the "new" libraries but I'm getting very similar results to those of ribo. Has the libraries changed in the last ~20 days?
-AM
amconcepts
Postby Mike H » Thu Jul 12, 2012 12:28 am
I am also having trouble with negative readings. Seem to hover around -200 C to -300 C at room temp and it jumps around a lot. I can get it up to about -50 C if I pinch it between my fingers. Trying to determine if it is a bad board, thermocouple, or code. Internal temp appears to read fine. Anyone else still having trouble with this?
Mike H
Postby adafruit_support_bill » Thu Jul 12, 2012 5:10 am
Make sure you have the latest libraries, and add a 0.1uF cap at the terminal block in parallel with the thermocouple.
PreviousNext
Users browsing this forum: No registered users and 5 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
