I was curious to know if there was a simple way to write data to a USB drive or SD card from a Flora? I'm trying to log pressure sensor data that is continuously being read by Flora.
Hope you can help, thanks!
Data Logging with Flora
Re: Data Logging with Flora
You can use an SD card.. that's easy. We have breakouts that will hold the card and a software library that will handle everything.
Using a USB drive would be hard. The Flora's microcontroller is capable of acting as a USB master, but none of the existing code supports it. You'd pretty much have to start from scratch.
- cheshmat1
Hi Mike,
Just to clarify, I am able to use https://www.adafruit.com/products/254 to interface directly with Flora and write to an SD card with just the break out board and Flora? Right now I was under the impression that I would need https://learn.adafruit.com/adafruit-data-logger-shield/ and an Arduino to do this.
Let me know, thanks!
- adafruit_support_bill
The shield contains an SD card interface (essentially the same circuitry as on the #254 micro-SD breakout) and a DS1307 Real-Time Clock.
If you want time-stamps in your log, then you can use the shield, or the #254 plus the #264 Real Time Clock breakout.
https://www.adafruit.com/products/264
However, there is an incompatibility between the 3.3v Flora and the 5v DS1307. You will need a level shifter in between
https://www.adafruit.com/products/757
This would apply to the shield as well as the breakout.
