How do i use the optional button on the proto shield?
Postby ronaldrperez » Wed Oct 14, 2009 11:38 am
Which pins is it connected to?
Thanks,
Ronald
ronaldrperez
Re: How do i use the optional button on the proto shield?
Postby ahdavidson » Wed Oct 14, 2009 11:49 am
It's not connected to any pin, but you can connect it to one by soldering a wire to the board and then using that wire in a pin. It's very handy!
There's an explanation and photo in the penultimate step of the instructions on this page.
.andy
ahdavidson
Postby ronaldrperez » Fri Oct 16, 2009 12:29 am
Thanks :D
-Ronald
ronaldrperez
Postby hlship » Thu Dec 03, 2009 5:54 pm
I'm very new to hardware and arduino.
It seems to me that the protoshield could be more useful if there were built-in pins for the switch and the two leds.
Forgive me if I get the terms wrong.
I'm thinking about adding a male header with three pins. One could be connected to a digital input pin to read the button. The other two could be connected to digital output pins to light the leds.
So I should be able to run a wire from the header to the holes marked led 1 and led 2 ... each of these leds appears to have a current limiting resistor already. I think I can see how power can run to that hole, follow the trace to and through the resistor, and then into the led itself. I know its on the schematic, but I have a hard time relating that to the board (everything's so tiny).
From what I've read, I need a pull up resistor to use the switch ... I'm a bit confused, but I think this means that I should connect the header to +5V via the resistor, but also connect the same header to the switch. I have to assume this would be to the hole marked "+". End result: the input pin will read HIGH until the button is pressed.
To be honest, this is like thinking in a foreign language; I'm really confused about the switch part (for some reason, I "get" pull down resistor easier than pull up).
Anyway, just looking for comments, criticisms and thoughts.
hlship
Users browsing this forum: mibignistinly and 1 guest
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
