16x2 LCD doesn't work correctly when powered on
kjata1013
Re: 16x2 LCD doesn't work correctly when powered on
Post by kjata1013 »
So, I had this problem too. I haven't used my LCD in a few weeks. Before that I was using Pins 7, 8, 9, 10, 11, 12 and had no issues what so ever. I used this set up that I have attached a million times before, no problems. Went to use it today and no matter what I did, I got one line of blocks and nothing else. Even this really easy code:
#include <LiquidCrystal.h>
LiquidCrystal lcd (7, 8, 9, 10, 11, 12);
void setup()
  lcd.begin(16, 2);
  lcd.print("Yo");
void loop()
  lcd.setCursor(0, 1);
  lcd.print(millis()/1000);
I found this thread, changed pin 7 to 6 and it works fine. Any ideas why it would stop working like that?
What other things have you been doing with your Arduino since the lat time you had the LCD hooked up? One possibility is that your pi 7 was damaged somehow. It is also possible that the breadboard connection next to that pin is bad. You might have better luck using another breadboard hole for your jumper.
kjata1013
Post by kjata1013 »
Hrm. That's interesting. Well, I tried 2 different bread boards. I have a mini breadboard, then I tried it on my MakerShield. I have a tiny breadboard on there. I just last night finished the AVR shield and had been moving it on and off of the MakerShield. It was a tight fit because I didn't have my Arduino to put the header pins on, I had to tape them on and keep them straight, maybe I damaged it that way. Shoot. Other than that, the LCD's been sitting in a box in my room. Tsk. I'll have to test the breadboards and the MakerShield....Thanks for your help!
Return to “Other Arduino products from Adafruit”
