Big problem with Mini Thermal Receipt Printer
Re: Big problem with Mini Thermal Receipt Printer
Postby adafruit_support_rick » Fri May 25, 2012 7:30 am
OK. But what happens if you put in printer.println(line), but take out SD.open, datafile.println(line), and SD.close()?
Postby 9six4 » Fri May 25, 2012 7:42 am
Nothing change. The problem is ONLY the printer.println(line) couse it goes crazy also with the printer not connected (no digital pins connected and no GND). If I connect the printer to digital pins 8 and 9, and also common GND but drop printer.print command it works fine.
I think the problem is just in this command. I've also tried with a while cycle or putting printer.print outside the main cycle with a void printing(); function, but no way.
9six4
Postby adafruit_support_rick » Fri May 25, 2012 7:57 am
The only thing that makes sense is that you are running out of RAM. The SD library will use a lot of RAM. Please remove EVERYTHING related to SD from your sketch - the header file and everything in setup() and loop(), and try it again with the printer.
Postby 9six4 » Fri May 25, 2012 8:16 am
Ok, I used this code:
#include <SoftwareSerial.h>
#include <Adafruit_Thermal.h>
int printer_RX_Pin = 8;  // this is the green wire
int printer_TX_Pin = 9;  // this is the yellow wire
Adafruit_Thermal printer(printer_RX_Pin, printer_TX_Pin);
  Serial.begin(1200);
  printer.begin();
String line = "";
  if (Serial.available()) {
    char inByte = Serial.read();
    switch (inByte) {
      case '\n':
        Serial.println(line);     //print complete line
        printer.println(line);
        line = "";                    //reset to empty string
      break;
    default:
      line += inByte;           //append inByte to the line String
I've also disconnected the sd shield. No way! Same problem, but I think you can see it also in the serial monitor: when I have the printer.print command active it use another way to write lines on the scree:
0XE()
0XFE()
0X20()
If you drop the printer,print command you have a good printing on the serial monitor:
kT1 27.7C Lo 27.7 Hi 27.7
Why this? I think it's just a libraries problem, I think something in Adafruit_Thermal.h or SoftwareSerial.h take crazy my code. I have tried also with an Arduino Mega 2560... same problem!
9six4
Postby adafruit_support_rick » Fri May 25, 2012 10:35 am
I've been trying to duplicate your problem, but I cannot reproduce the issue.
what version of Arduino are you using?
What versions of the libraries are you using? Are they all Adafruit libraries?
Something odd - I copied and pasted your exact code into a new sketch, but it did not compile because it did not include Wire.h.
How is it that it compiles for you without including Wire.h?
Postby 9six4 » Fri May 25, 2012 10:57 am
Good question but I don't know. Now I try with.
Arduino UNO R3, Arduino Mega 2560. IDE 1.0
I followed adafruit instructions:
http://www.ladyada.net/make/logshield/download.html
9six4
Postby adafruit_support_rick » Fri May 25, 2012 11:28 am
0XE()
0XFE()
0X20()
This is expected. Adafruit_Thermal does this normally.
edit: There is now a new version of the library in GitHub which does not output these lines to Serial
Postby 9six4 » Fri May 25, 2012 3:06 pm
YEAHHHHHHHHHHHH!!! Now it seems to work!!! I downloaded new version of library from the link you gave me and I also added wire.h and now it seems to be ok.
I couldn't test the printings couse I left the thermal paper in my office, but before missed even without the printer connected.
On monday I'll do a full test. Thank you so much driverblock, I really appreciated your help!
Have a good weekend, and thank you again!
9six4
Postby 9six4 » Thu May 31, 2012 8:19 am
Hi everyone, I've hard-tested the printer and it seems to work fine. I've used a 12V 800mA and it had no problems.
Is it possible to update the file date when it's saved? My files display always 01/01/2000 date.
Thank you so much
Alberto
9six4
Postby 9six4 » Thu May 31, 2012 10:08 am
Thanks for your prompt reply. Take this opportunity to congratulate you for being inserted into the top 100 brilliant companies 2012.
9six4
Postby 9six4 » Thu May 31, 2012 12:23 pm
I tried to read the AnalogLogger but I can't understand that kind of code. I think the right procedure is this:
// call back for file timestamps
void dateTime(uint16_t* date, uint16_t* time) {
    DateTime now = RTC.now();
  // return date using FAT_DATE macro to format fields
  *date = FAT_DATE(now.year(), now.month(), now.day());
  // return time using FAT_TIME macro to format fields
  *time = FAT_TIME(now.hour(), now.minute(), now.second());
and this:
SdFile::dateTimeCallback(dateTime);
  cout  << now << endl;
But I don't know how to integrate them on my code:
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
#include <LiquidCrystal.h>
#define SYNC_INTERVAL 10000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL   1 // echo data to serial port
#define WAIT_TO_START    0 // Wait for serial input in setup()
// the digital pins that connect to the LEDs
//#define redLEDpin 2
//#define greenLEDpin 3
RTC_DS1307 RTC; // define the Real Time Clock object
const int chipSelect = 10;
File logfile;
void error(char *str)
  Serial.print("error: ");
  Serial.println(str);
  while(1);
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
void setup(void)
  Serial.begin(1200);
  Serial.println();
  lcd.begin(20,4);
  printer.begin();
  //use debugging LEDs
  //pinMode(redLEDpin, OUTPUT);
  //pinMode(greenLEDpin, OUTPUT);
  // initialize the SD card
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    error("Card failed, or not present");
    //digitalWrite(redLEDpin, HIGH);
  Serial.println("card initialized.");
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  if (! logfile) {
    error("couldnt create file");
  Serial.print("Logging to: ");
  Serial.println(filename);
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
    logfile.println("RTC failed");
#if ECHO_TO_SERIAL
    Serial.println("RTC failed");
#endif  //ECHO_TO_SERIAL
  logfile.println("millis,stamp,datetime,data");
  }    //end SETUP
String line = "";
void loop(void)
    switch (inByte) {
      case '\n':
        //digitalWrite(greenLEDpin, HIGH);
        lcd.setCursor(0,0);
        lcd.print(line);
        // if the file is available, write to it:
        if (logfile){
          DateTime now;
          // log milliseconds since starting
          uint32_t m = millis();
          logfile.print(m);           // milliseconds since start
          logfile.print(", ");
          // fetch the time
          now = RTC.now();
          // log time
          logfile.print(now.unixtime()); // seconds since 1/1/1970
          logfile.print('"');
          logfile.print(now.year(), DEC);
          logfile.print("/");
          logfile.print(now.month(), DEC);
          logfile.print("/");
          logfile.print(now.day(), DEC);
          logfile.print(" ");
          logfile.print(now.hour(), DEC);
          logfile.print(":");
          logfile.print(now.minute(), DEC);
          logfile.print(":");
          logfile.print(now.second(), DEC);
          logfile.print('"');
#if ECHO_TO_SERIAL
          Serial.print(now.unixtime()); // seconds since 1/1/1970
          Serial.print(", ");
          Serial.print('"');
          Serial.print(now.year(), DEC);
          Serial.print("/");
          Serial.print(now.month(), DEC);
          Serial.print("/");
          Serial.print(now.day(), DEC);
          Serial.print(" ");
          Serial.print(now.hour(), DEC);
          Serial.print(":");
          Serial.print(now.minute(), DEC);
          Serial.print(":");
          Serial.print(now.second(), DEC);
          Serial.print('"');
          logfile.println(line);
        //digitalWrite(greeLEDpin, LOW);
        break;
      default:
  if ((millis() - syncTime) < SYNC_INTERVAL) return;
  syncTime = millis();
  logfile.flush();
  //digitalWrite(redLEDpin, LOW);
9six4
Postby 9six4 » Thu May 31, 2012 12:27 pm
I've tried doing this:
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
File logfile;
  while(1);
void setup(void)
  Serial.begin(1200);
  Serial.println();
  lcd.begin(20,4);
  printer.begin();
  if (! logfile) {
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
#if ECHO_TO_SERIAL
  }    //end SETUP
String line = "";
void loop(void)
    switch (inByte) {
      case '\n':
        lcd.setCursor(0,0);
        lcd.print(line);
        if (logfile){
          DateTime now;
          // fetch the time
          now = RTC.now();
          // log time
          logfile.print('"');
          logfile.print("/");
          logfile.print("/");
          logfile.print(" ");
          logfile.print(":");
          logfile.print(":");
          logfile.print('"');
#if ECHO_TO_SERIAL
          Serial.print(", ");
          Serial.print('"');
          Serial.print("/");
          Serial.print("/");
          Serial.print(" ");
          Serial.print(":");
          Serial.print(":");
          Serial.print('"');
        break;
      default:
  logfile.flush();
But it can't compile:
RS232_man_ok1.cpp: In function 'void setup()':
RS232_man_ok1:77: error: 'cout' was not declared in this scope
RS232_man_ok1:77: error: 'endl' was not declared in this scope
9six4
Postby adafruit_support_bill » Thu May 31, 2012 1:15 pm
"cout" is declared in the original code:
// Serial print stream
ArduinoOutStream cout(Serial);
PreviousNext
Return to Other Arduino products from Adafruit
Users browsing this forum: No registered users and 3 guests
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
