Fingerprint problem - Arduino UNO
Re: Fingerprint problem - Arduino UNO
by adafruit_support_bill on Wed Sep 26, 2012 1:18 pm
Not sure what else to try here. All the individual parts are working - just not together. :?
If you have a soldering iron, you can try soldering some header pins (or just heavier gauge wire) to the ends of the sensor wires. The thin wires do not always make a reliable connection in the breadboard.
by ABadDream on Thu Oct 18, 2012 9:38 pm
Hi
I downloaded the fingerprint library two days ago and happened the same.
What I found out is that in "Adafruit_Fingerpring.CPP" in line 49 col 32, there's a typo. It is a condition to be met and there's only one = character.
line goes
if ((len == 1) && (packet[0] = FINGERPRINT_ACKPACKET) && (packet[1] == FINGERPRINT_OK))
and must be
if ((len == 1) && (packet[0] == FINGERPRINT_ACKPACKET) && (packet[1] == FINGERPRINT_OK))
Also changed speed on SFGDemo from 115200 to 57600.
It worked well with fingerprint example, hope it helps.
ABadDream
by adafruit_support_bill on Fri Oct 19, 2012 8:08 am
Thanks for reporting that. I've entered it as an issue on the Github repository.
by mxlukax on Fri Oct 26, 2012 7:09 am
Thanks for help me, now it's working. :D
mxlukax
by ABadDream on Mon Oct 29, 2012 3:24 pm
Hey, It's me again.
Found now a problem on fingerprint example, So I got into the code again.
I was trying to get response if I entered a id that was not in the finger reader, but nothing happened. Only was able to get response when an enrolled fingerprint was entered. So I found this.
In the example says:
void loop()
getFingerprintIDez();
and must say:
void loop()
getFingerprintID();
delay(2000); //This was added by myself to have the reader waiting between readings.
It works now with all the messages and error messages.
Regards
ABadDream
