Fingerprint Sensor : Retrive RAW Image
by harryhaaren on Thu Nov 08, 2012 6:23 pm
I've recently purchased the fingerprint scanner that you offer, and have got off to a great start using it. The examples are working fine, the only issue that I'm having is that there is little documentation on how to get access to the raw image data.
As far as I understand the sensor provides 255x288 pixels of 16 bit greyscale data in a bitmap form. I read the header file available on github.com, and presume it requires the use of finger.getImage() and finger.getReply(). I'm a little lost as to how to perform the details.
Help explaining how to retrieve the raw data into the Arduino, and how that data should be interpreted to be viewable as a greyscale image would be much appreciated :)
Cheers, -Harry
harryhaaren
Re: Fingerprint Sensor : Retrive RAW Image
by adafruit_support_bill on Fri Nov 09, 2012 6:59 am
We recently got the English translation of the manual and have posted it here: http://learn.adafruit.com/adafruit-opti ... /downloads
I have not had a chance to study it to see what raw image support they have.
by harryhaaren on Fri Nov 09, 2012 7:22 am
adafruit_support wrote:We recently got the English translation of the manual and have posted it here: http://learn.adafruit.com/adafruit-opti ... /downloads
Thanks for the reply. I've read trough the linked datasheet, and although it does provide some insight into the image format (255x288 px , 4 bits or 16 shade when transferred over UART) it doesn't mention how to get the data from the device.
Essentially my question is how I can use the functions getImage() and getReply() provided as on github https://github.com/adafruit/Adafruit-Fingerprint-Sensor-Library/blob/master/Adafruit_Fingerprint.h#L83 to retrive the image data.
Cheers, -Harry
harryhaaren
by adafruit_support_bill on Fri Nov 09, 2012 7:41 am
getImage() in the library is an implementation of the 0x01 command which is described like this in the manual:
6.2.1 To collect finger image: GenImg
Description: detecting finger and store the detected finger image in ImageBuffer while
returning successfull confirmation code; If there is no finger, returned
confirmation code would be ¡ can¡t detect finger¡ .
Uploading the image from the sensor would be the 0x0A command. We did not have this level of English language documentation at the time the library was written, so we currently do not have library support for this function.
by mxlukax on Fri Jan 18, 2013 9:13 am
Someone know how can i get the image raw data ?
mxlukax
by dolsh on Sat May 25, 2013 6:40 pm
i'm having the same problem i need to know how to pass the data image from the sensor to th pc through the arduino
dolsh
by adafruit_support_bill on Sun May 26, 2013 5:56 am
The English version of the manual is available now here: http://www.adafruit.com/datasheets/ZFM% ... ualV15.pdf
new po
by syed sajjad on Sun Feb 23, 2014 5:38 pm
i need all commands like getImage(),image2Tz of adafruit_fingerprint liberary. please let me know as soon as possible
syed sajjad
by saeid on Fri Feb 06, 2015 10:58 pm
Can anyone post a code that reads raw image from the image buffer and save it to a file?
saeid
by saeid on Sat Feb 07, 2015 5:33 pm
Dear Adafruit,
I recently purchased the fingerprint kit which comes with the Arduino uno board. The reason I purchased this kit was to capture raw fingerprint images.
I'v been trying for a few days with no success. The SFG Demo software is clearly a joke. I could actually "open the device" but I cannot communicate with the device. For example when I set the baud rate to 57000 it says "Failed to set bandrate". I followed all the suggestion in the forum, even tried with windows 7 and 8.
Then I decided to do some coding so I can get the image. I have the same problem as everyone else. The received data is approximately 19000 bytes which is much less than the image buffer should be. Every time I sent a request for the buffer, the data received is different.
I don't have much time to spend on this and clearly it didn't work for many others. Hence I am writing this to request for refund.
Best,
Saeid
saeid
by adafruit_support_mike on Sat Feb 07, 2015 9:21 pm
That would fall under the heading of a return by choice, so we'll need you to pay return shipping.
Send a note to support@adafruit.com with a link to this thread and the folks there will help you.
