IR remote not working
by wdickenson on Fri Nov 16, 2012 8:49 pm
I have just hooked up the IR sensor to my Uno and I am using the mini-remote.
When I use the examples in the adafruit library, i get a "Data error" and a repeat when it's the same key.
When I run the example from arduino cookbook, I see a ton of data. But the example for this remote seems to give me errors when running.
What am I doing wrong ? Code is the code in the github.
wdickenson
Re: IR remote not working
by adafruit on Fri Nov 16, 2012 9:49 pm
make sure you download the latest version of our library
https://github.com/adafruit/Adafruit-NE ... ol-library
updated recently!
by wdickenson on Sat Nov 17, 2012 11:29 am
Still not working -
I went back and deleted the libraries and picked up a new version of the code. I will likely try to uncomment the Serial.println functions from the library (although that is new for me).
it senses the end of the key press, it knows that it received a duplicate code, but it just is not translating the code.
Any other thoughts ?
btw: as long as I am in the asking mode, I was planning on putting this in an interrupt on pin 3. Any issues with that ?
Thanks for your help. I will take all the suggestions I can get.
wdickenson
by adafruit on Sat Nov 17, 2012 2:39 pm
hmm can you post a photo of the remote and sensor?
by wdickenson on Mon Nov 26, 2012 11:07 am
I went back and pulled the original IR code and the Arduino cookbook code and it all seems to work. I'm not sure why the library code did not but I've got what I needed. Thanks
wdickenson
