Ultimate GPS for stratospheric Balloons
by agassichan on Fri Nov 23, 2012 11:08 am
I would like to use your Ultimate GPS on stratospheric balloons.
I've read you've got fix up to 27km. Does this means that it didn't worked on higher altitudes, or the balloon didn't arrived higher than that?
Anyone used it up to 36km or similar?
Thanks for your help,
Jose Luis
agassichan
Re: Ultimate GPS for stratospheric Balloons
by adafruit_support_bill on Fri Nov 23, 2012 1:32 pm
That is the highest altitude we have a confirmed test for so far. The manufacturer has removed firmware limits on altitude for us.
by adafruit on Thu Nov 29, 2012 12:18 pm
Another person confirmed 102,998.69 feet! (31,394 meters)
by agassichan on Thu Nov 29, 2012 12:25 pm
Thanks for your help.
That means for us that is correctly working. Let's hope we can confirm something more close to 40km :D
agassichan
by agassichan on Fri Feb 08, 2013 7:53 am
I've recently received a v3 version (1 week ago).
I've seen someone tested something and identified two different firmwares:
http://ukhas.org.uk/guides:adafruitugps
Mine, unfortunately is supposed to work only up to 27km, and this is not useful for me.
Is some way of flashing a new firmware?
agassichan
by adafruit_support_bill on Fri Feb 08, 2013 9:15 am
These are pre-flashed at the factory. We do not have the facilities to re-flash them.
by agassichan on Fri Feb 08, 2013 9:26 am
In future purchases, is there some way of getting the 40km altitude firmware?
agassichan
by adafruit_support_bill on Fri Feb 08, 2013 9:30 am
Where did you get yours from? All current stock should be with the new firmware.
by agassichan on Fri Feb 08, 2013 10:00 am
I've got it from your web store. Purchase order 225384. The tracking says it's not delivered, but I have it
agassichan
by adafruit on Fri Feb 08, 2013 11:06 am
Hi - there's a little bit of misinformation going on. We sent a beta test firmware out to a UK tester to verify it can do higher altitude. However, -no- GPS modules we sell have that firmware on it. We had requested from the factory that our next shipment come with the newer higher-altitude firmware but that shipment hasnt arrived yet. The only GPS with the new firmware is the one the beta tester received. Once we do get the next delivery, all the GPS modules we make will come with the new firmware. However, that is 2 or 3 weeks away at best.
It seems like that beta tester went ahead and wrote up about our test without alerting us, causing much confusion because he had the single test module and there is no way to upgrade current burned firmware with the new higher-alt firmware :(
you can email support@adafruit to get a refund for your GPS but please alert that website that we are not selling that firmware (yet) and to please not get people's hopes up until we do :) We will post on the blog when we get the new firmware in!
by mbodo on Tue Feb 19, 2013 3:48 pm
I noticed that your stock status of the Ultimate GPS was recently out-of-stock but is now in-stock. Does your current inventory of Ultimate GPS breakout boards contain the GPS firmware that enables use of the module at or above 40km altitude for high altitude balloon use?
mbodo
by buton on Tue Feb 19, 2013 5:20 pm
Same question, i just ordered one today ...
buton
by adafruit_support_rick on Wed Feb 20, 2013 12:15 pm
@mbodo, @buton -
I'm sorry, but the answer is no.
by mbodo on Fri Feb 22, 2013 8:37 pm
Do you have an updated eta when you will have the 40km firmware version in stock?
mbodo
by adafruit on Fri Feb 22, 2013 11:26 pm
mbodo wrote:Do you have an updated eta when you will have the 40km firmware version in stock?
we do not.
