Random 0x66 error writing to USB Boarduino
by ubestbsteppin on Fri Jan 04, 2013 6:41 pm
My USB Boarduino started giving me an error while writing to it. Everything was working fine the first dozen or so times I uploaded my sketch, the next minute the Arduino IDE (1.0.1 and 0023) is reporting "avrdude: stk500_getsync(): not in sync: resp=0x66". The IDE says "done uploading" but the new code hasn't been uploaded. Any idea what is going on or what else I could try?
ubestbsteppin
Re: Random 0x66 error writing to USB Boarduino
by JD3 on Fri Jan 04, 2013 9:59 pm
I have the same problem - one minute it works, then it doesn't want to upload.
Then I look at the jumper by the reset switch - oops i have it set for external power not usb....
And you would not believe how many times I keep doing that......
That little black caterpillar you just stepped on will set you back a few bucks....
JD3
by adafruit_support_bill on Sat Jan 05, 2013 7:22 am
Check the jumper as JD3 suggests. Also double check the COM port. They do get re-assigned sometimes - especially if you plug the cable into a different USB port.
cron
