Max31855 v2 ferrite bead replacement
by bheiss on Mon Jan 21, 2013 8:11 am
I have dammaged what seems to be one of the ferrite beads on the board. (element right of "Red")
With what can I replace the ferrite bead and/or what are the specification of the element, so that I can replace it ?
Schematics that I found on Github seem to be showing Max31855 V1 board ( https://github.com/adafruit/Adafruit-MAX31855-breakout-board) without any beads.
Tx for your advise !
Encl.: v2 board with dammaged ferrite bead ?
max31855 v2 dammaged ferrite bead (1280x960).jpg (168.73 KiB) Viewed 863 times
bheiss
Re: Max31855 v2 ferrite bead replacement
by adafruit on Mon Jan 21, 2013 11:37 am
you can use any ferrite bead but a piece of wire will suffice as well, there's two beads and a capacitor - the capacitor is the most important part :)
by bheiss on Mon Feb 04, 2013 11:07 am
Tx !
Soldering a piece of wire instead of a bead solved my problem !
bheiss
by h4wk3y on Thu Jun 05, 2014 4:14 pm
Hello, please, can you write, which ferrite is really used in original - which parameters does it have?
Have the same problem as bheiss...
h4wk3y
by adafruit_support_mike on Sat Jun 07, 2014 12:36 am
I think we're using 300 ohm 0805s right now, but the value isn't specified because it isn't critical, or even important.
