Continuous Rotation Servo backwards compatible with Standard Servo
by rahatmaini on Thu Jan 24, 2013 7:45 pm
There is a ton of code out there that works only with standard servos because they rotate 180 degrees. Because that is a range of 0-180, sketches on the Arduino can use functions like map(); perfectly.
I want to be able to use a joystick to control two continuous rotation servos in a pan-tilt system. I can already do this although it is not precise and perfect at all. I want to use Standard Servo code with Continuous rotation servos.
I need to have my Continuous Rotation Servos behave like Standard Servos temporarily. How?
rahatmaini
Re: Continuous Rotation Servo backwards compatible with Standard Servo
by adafruit_support_bill on Thu Jan 24, 2013 7:50 pm
This is not possible. A continuous rotation servo is a standard servo with the physical stops removed and the feedback circuit disconnected from the shaft. Without feedback a servo cannot determine its position.
by arctic_eddie on Thu Jan 24, 2013 8:11 pm
You can try Dynamixel servos. They are continuous rotation, high precision, absolute positioning, and digital control using either RS485 or half-duplex RS232. The AX-12 series will work but the RX, MX, and EX series are much better, but quite expensive. The later are 4096 steps per revolution.
arctic_eddie
by rahatmaini on Thu Jan 24, 2013 8:42 pm
Thanks ArcticEddie!
rahatmaini
cron
