ttl camera software
ttl camera software
by chris220013 on Fri Jan 25, 2013 6:10 am
Ive downloaded the TTL camera software and libraries from the tutorial web site and keep getting these errors when trying to compile the program:
Adafruit_VC0706 does not name a type
and
in function void setup()
error cam was not declared in this scope
error VC0706_640x480 was not declaied in this scope
error VC0706_320x240 was not declaied in this scope
error VC0706_160x120 was not declaied in this scope
Im using 1.0.2 software and a uno board
Any help would be appreciated
chris220013
Re: ttl camera software
by adafruit_support_bill on Fri Jan 25, 2013 7:59 am
That means that the IDE was not able to find the library. Make sure that you close all copies of the IDE (It won't find libraries that are installed while it is running).
And follow the instructions here to make sure it is installed in the correct location: http://learn.adafruit.com/arduino-tips- ... -libraries
by chris220013 on Fri Jan 25, 2013 8:54 am
Thanks for the help, ive found the error in the library file but now ive got
Error compiling
and a mass of errors that look like
\Arduino\libraries\Adafruit_VC0760/Adafruit_VC0760.h:9 error: stray '\302' in program
\Arduino\libraries\Adafruit_VC0760/Adafruit_VC0760.h:254 error: stray '#' in program
the list goes on and on
Thanks for the help in anticipation
chris220013
by adafruit_support_bill on Fri Jan 25, 2013 9:13 am
Looks like you have an invalid character in your file. If you edited the file at all, your editor may have inserted characters that the compiler does not recognize. Better to start with a fresh download of the library.
