Weatherproof TTL Serial JPEG Camera with NTSC Video and IR LEDs
Re: Weatherproof TTL Serial JPEG Camera with NTSC Video and IR LEDs
by adafruit_support_bill on Mon Jan 28, 2013 9:21 pm
If all the commands are timing out, then it is no surprise that you don't see any image. Post photos showing all of your connections.
by anibalr on Tue Jan 29, 2013 8:52 pm
See attachment for the connections.
photo (13).JPG (272.81 KiB) Viewed 620 times
anibalr
by anibalr on Tue Feb 05, 2013 4:17 pm
Hey, I have not heard from adafruit about connecting the camera.
anibalr
by adafruit_support_bill on Tue Feb 05, 2013 6:24 pm
On the waterproof camera, the green wire (Rx) should be wired through the voltage divider.
by anibalr on Tue Feb 05, 2013 10:01 pm
Ok I got it. I connected the white on pin 2 and green on pin 3 and it works. However, I am now using the MEga 2560 with the sd card that I bought from Adafruit. I have already downloaded the library. I need some help, now that I have the camera working, do I need to make ay changes to the code if I am using the Mega instead of the arduino uno for the SD card.
anibalr
by adafruit_support_bill on Tue Feb 05, 2013 10:21 pm
Are you using the Micro SD breakout board? http://www.adafruit.com/products/254
by anibalr on Fri Feb 08, 2013 2:22 pm
Ok, Got it thanks.
anibalr
