Defective Flow Meter?
by 3vilpenguin on Thu Jan 31, 2013 12:01 am
I ordered the arduino capable flow meter, and it doesn't work. I spent a few days troubleshooting it, no luck!
I've successfully had the seeed version a while ago, so I'm sure it's not a bad schematic.
The code is the sample code from https://github.com/adafruit/Adafruit-Flow-Meter
The schematic: arduino Digital 2 to the yellow pin (sensor), 5v (via the arduino 5v pin) to the red input (5v), and grounded to the arduino ground. It picks up 0 for all it's readings.
3vilpenguin
Re: Defective Flow Meter?
by adafruit_support_bill on Thu Jan 31, 2013 7:37 am
Is this the plastic or brass-bodied meter? The wiring & code are the same for both & if the Seeed version works in the same circuit, there must be a problem with that unit.
If you contact support@adafruit.com with a link to this thread we can replace that for you.
