Winter Storm Juno: Blizzard Warning! All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
Flora GPS Starter Pack: Flora not detected on a mac
by fredfredburger on Sat Feb 02, 2013 9:30 am
Hello!
I was following the instructions on the getting start with flora page, and had problems with getting it detected on my mac (10.8.2). No x.usbmodem.x entry show up on the Tools menu (just two Bluetooth ones), and nothing special listed on /dev/tty*.
I tried installing newer FTDI drivers and they are loaded but nothing new shows up. If anything, the entry /dev/ttys002 got a new timestamp when I reloaded the FTDI driver.
The green light is on (steady) and the red one is blinking. What else am I missing?
Update: I also tried using the regular Arduino ide on ubuntu and copied board.text and the flora variants dir into the arduino ide's dir. Serial Port from the tools menu is disabled and when running lsusb, I don't get my device listed.
fredfredburger
Re: Flora GPS Starter Pack: Flora not detected on a mac
by fredfredburger on Wed Feb 06, 2013 8:37 pm
Also, should it make a difference that I bought the starter pack from MakerShed? I did that since the pack was out of stock from adafruit and was being impatient :(
Is there any other information missing from here?
fredfredburger
by sanju_gem on Thu Feb 07, 2013 4:22 pm
I am having quite a problem installing flora in windows :( . It does not updates the driver given on this link
http://learn.adafruit.com/getting-start ... d-software
my screen shows something like this
Screenshot On windows driver install
sanju_gem
by fredfredburger on Thu Feb 07, 2013 10:49 pm
@sanju_gem: I tried this on windows 8 as well at device manager kept crashing when i would connect the flora and click the scan for new devices button. Didn't post it here since it might have been my windows 8 install. It's weird not seeing it listed under lsusb or anything!
fredfredburger
by sanju_gem on Fri Feb 08, 2013 6:32 am
@fredfredburger yes, i started new thread for windows installerhttp://forums.adafruit.com/viewtopic.php?f=22&t=36924&p=182173#p182173 ,
and yes your right it crashes a lot ..I tried on Mac and linux both has same problem as u said , no serial device is listed . I went through a lot of other posts. I found few of them posting that its watchdog, which is resetting every time and making problem in this micro-controller http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&p=797991 . I am not sure how long will it take for Adafruit Experts solving this problem but i really need this for my wearable experiment .
I will post update here as soon as its solved .
sanju_gem
by fredfredburger on Fri Feb 08, 2013 9:15 pm
Thanks sanju for updating. I should try out what you linked to...will update here if it works.
fredfredburger
by fredfredburger on Sat Feb 16, 2013 9:38 pm
Some more debugging on a mac (10.8.2) to see if the same problem of no device being recognized in ubuntu (using the lsusb command).
First I ran this command that would list all devices (I didn't want to use the hardware type utility since it's harder to diff info):
$ system_profiler SPUSBDataType > normal
Then I plugged the flora in and waited for a few seconds. Then ran a similar command
$ system_profiler SPUSBDataType > after
Then I diffed the two
$ diff normal after
No output, so nothing different...and no new device detected on a mac.
fredfredburger
by fredfredburger on Sat Feb 16, 2013 10:55 pm
@sanju regarding the second forum link, it's not possible to debug by uploading barebones firmware code with debug lines, since the flora can't be mounted. So I'm pretty much stuck still.
fredfredburger
by adafruit_support_rick on Sun Feb 17, 2013 3:05 pm
@fredfredburger - Try different USB cables and USB ports on your computer. If that doesn't help, try attaching the Flora through a powered USB hub. Since you're running 10.8, I'll assume you have a newer Mac with USB 3.0 ports. We've been seeing some scattered problems with USB 3.0. Sometimes using a powered hub helps with that. In any case, there is a wide range of quality in seemingly identical USB cables. Communication problems are often cured by switching to a different cable.
by fredfredburger on Tue Feb 19, 2013 12:54 pm
Thanks! I'll try that when I get home -- I did try different mini-USB cables and no luck, but good point, I'll try a powered usb hub.
Also I did try it on my ASUS U30JCB1 which has usb 2.0 ports, and ubuntu didn't list the flora when executing lsusb... will try that anyway.
fredfredburger
by fredfredburger on Thu Feb 21, 2013 11:02 pm
So I tried it with the powered usb hub (with usb 2.0 ports). USB prober could recognize the hub with 4 ports, but when I would connect the flora to the hub, the status of that port wouldn't change from not-responding to something normal.
USBPortStatuswithouthubandflora.txt
(3.15 KiB) Downloaded 42 times
USBPortStatuswithhubandflora.txt
(3.34 KiB) Downloaded 35 times
I tried this in either of the two ports on my macbook. I also tried using an unpowered USB A/A cable and then connected the flora but there was no change.
Do you know which specific kext is related to the flora com driver? I've been unloading and loading those, but it looks like most of the AppleUSBCDC* ones aren't used. Also reloaded the IOUSB one.
fredfredburger
by adafruit_support_rick on Fri Feb 22, 2013 12:26 pm
Well, it sounds like you've got a bum Flora there. You'll have to contact MakerShed for a replacement.
by Tiptaptopal on Sun Dec 28, 2014 7:40 pm
I'm having the same problem with the Flora. It is not identifying a usbmodem in the serial port, is there any updates that have solved this problem? I'm on a Mac, and My green light is on and the red light is blinking, but I don't see any other option on Serial Port other than bluetooth ones. I've changed the USB ports, and that hasn't made a difference.
Tiptaptopal
by adafruit_support_mike on Mon Dec 29, 2014 2:12 am
Connect the Flora to the Mac with a USB cable, launch the System Information program, and go to the USB pane. Check to see if there's an item in the list that has identified itself as "Adafruit Flora".
