chaining lcd on the pwm card?
by patrikk on Fri Feb 22, 2013 4:59 am
Is it possible to chain the LCD RGB display shield to the PWM card in the same way you would use multiple PWM cards or do I need the backpack?
they will be connected to Arduino Uno with the ethernet shield from Arduino.
https://www.adafruit.com/products/815 PWM
http://www.adafruit.com/products/714 LCD
patrikk
Re: chaining lcd on the pwm card?
by adafruit_support_bill on Fri Feb 22, 2013 10:00 am
You should be able to chain them. Just connect 5v, GND, SDA and SCL. There is no pin for chaining the reset line, so the reset button will not function unless you run a separate wire for it.
