Cannot upload sketches to Menta
by segfault on Sat Feb 23, 2013 11:05 am
Hi, I soldered together a Menta according to the instructions. The solder joints all look good. When I plug in external or USB power, the green power LED lights up. But when I press the reset button, nothing happens. (I understand from the instructions that the red LED should flash.) When I try to upload a sketch, I get the following error:
avrdude: stk500_recv(): programmer is not responding
How should I go about troubleshooting the device?
segfault
Re: Cannot upload sketches to Menta
by adafruit_support_rick on Sat Feb 23, 2013 2:47 pm
Are you attempting to use this with the Arduino IDE? How are you connecting to the menta? FTDI friend/FTDI cable? Have you selected the correct serial port in the IDE?
Post clear, detailed, focused pictures of both sides of the Menta board.
by segfault on Sat Feb 23, 2013 3:12 pm
Thanks for your hints!
- I'm using the Arduino IDE.
- I'm connecting with an FTDI cable
- The correct serial port is set.
My sister is making hi-res pictures of the board, I'll post them as soon as I get them. The solder joints look perfectly OK to me.
segfault
by segfault on Sat Feb 23, 2013 3:42 pm
Here are two pictures of the board:
segfault
by adafruit_support_rick on Sat Feb 23, 2013 3:57 pm
Hmmm ... that all looks good.
Try the procedure outlined here:
http://joekanedesign.com/blog/2012/11/a ... -solution/
by segfault on Sun Feb 24, 2013 9:21 am
Tried it a couple of times, didn't work :( The red LED blinks once, almost exactly when the stk500_recv() error message appears on screen. Any more ideas?
segfault
by adafruit_support_bill on Sun Feb 24, 2013 9:29 am
If the red led is not flashing on reset, you may have a bad (or missing) boot loader (the assembly looks fine). Contact support@adafruit.com with a link to this thread and ask for a replacement Menta processor.
