FloraPixel Problem
FloraPixel Problem
by tektsu on Sat Feb 23, 2013 8:32 pm
I have a number of Flora Neopixels (v2). Everyone of them blinks green with the sketch listed below. If instead I set color.green=255 and color.red=0;, it blinks red. Blue works as expected.
Is there a problem with the pixels? the libraries? am I using the wrong library?
#include "Adafruit_FloraPixel.h"
Adafruit_FloraPixel strip = Adafruit_FloraPixel(1);
RGBPixel color;
strip.begin();
strip.show();
color.red=255;
color.green=0;
color.blue=0;
strip.setPixelColor(0, color);
strip.show();
delay(500);
color.red=0;
color.green=0;
color.blue=0;
strip.show();
delay(500);
tektsu
Re: FloraPixel Problem
by pburgess on Sat Feb 23, 2013 10:02 pm
Earlier pixels were wired with red & green swapped...this is fixed in the current pixels, but the library was written for just the "classic" case.
I'd suggest downloading the NeoPixel library from github and using that instead of the FloraPixel library. It has some bells & whistles such as handling the different pixel types.
https://github.com/adafruit/Adafruit_NeoPixel
pburgess
by tektsu on Sat Feb 23, 2013 10:05 pm
Excellent! Thanks!
tektsu
by Bruzer on Thu Apr 11, 2013 12:52 am
I also noticed this Red is Green color problem with the NeoPixels v2 and the Adafruit_FloraPixel library. I tried several different sketches to prove to myself the colors were wrong. I thought I wired my pixels incorrectly or was going crazy! Glad I did a search here first.
I download the NeoPixel code on 04/10/2013 that you gave in the link but I can not get the strandtest example to compile.
Here is the error:
strandtest:10: error: 'Adafruit_NeoPixel' does not name a type
strandtest.pde: In function 'void setup()':
strandtest:13: error: 'strip' was not declared in this scope
strandtest.pde: In function 'void loop()':
strandtest:19: error: 'strip' was not declared in this scope
strandtest.pde: In function 'void colorWipe(uint32_t, uint8_t)':
strandtest:28: error: 'strip' was not declared in this scope
strandtest.pde: In function 'void rainbow(uint8_t)':
strandtest:39: error: 'strip' was not declared in this scope
strandtest:42: error: 'strip' was not declared in this scope
strandtest.pde: In function 'void rainbowCycle(uint8_t)':
strandtest:52: error: 'strip' was not declared in this scope
strandtest:55: error: 'strip' was not declared in this scope
strandtest.pde: In function 'uint32_t Wheel(byte)':
strandtest:64: error: 'strip' was not declared in this scope
strandtest:67: error: 'strip' was not declared in this scope
strandtest:70: error: 'strip' was not declared in this scope
I am using the Adafruit Flora and four Flora NeoPixel v2 pixels wired in series. I realize the strandtest sets up for the LED strip, so even when I change the Adafruit_NeoPixel constructor to: Adafruit_NeoPixel strip = Adafruit_NeoPixel(4, 6, NEO_RGB + NEO_KHZ400); I still can not compile it (and I get the same error).
What did I do wrong?
Bruzer
by pburgess on Thu Apr 11, 2013 1:27 am
Looks like the library might not be properly installed. Confirm that:
- The ZIP file was uncompressed after downloading (Windows lets you navigate into ZIP files as if they were folders, which can be confusing sometimes).
- The resulting folder has been renamed 'Adafruit_NeoPixel'
- This folder has been placed inside your personal Sketchbook/Libraries folder, and
- The Arduino IDE is restarted after installing the library
(Are you using 'Open...' to load the strandtest sketch, or are you able to access it directly from the File->Sketchbook->Libraries menu? Is an Adafruit_NeoPixel rollover menu present there? That's one way to tell if the library is correctly installed.)
pburgess
by Bruzer on Thu Apr 11, 2013 9:00 am
The files were downloaded individually and the directories were created the properly. I did not restart the Arduino IDE. After a restart the strandtest seems to be working correctly. Thank you for the troubleshooting steps!
You wrote that the older pixels have the red and green pixels swapped. I have the Flora NeoPixels v2 (that arrived in April 2013) but it seems I need to specify NEO_GRB for the "Color" to be created correctly.
Adafruit_NeoPixel strip = Adafruit_NeoPixel(4, 6, NEO_GRB + NEO_KHZ400);
Does this mean the pixels I have have red and green "backwards"? I would have expected to use the NEO_RGB with the version 2 NeoPixels, but when constant NEO_RGB is used strip.Color(255, 0, 0) is green and strip.Color(0, 255, 0); is red.
Thanks for the troubleshooting steps I learned how to properly load the library.
Bruzer
by joshlucy on Wed Sep 03, 2014 9:38 pm
Hello, this is a bit of an old thread, but I'm having a problem in the same vein. I'm attempting to drive some NeoPixel V1 pixels from an ATTINY85, and I'm getting some errors compiling the code when I switch to NEO_KHZ400. Do you have any advice? I'm using the most recent version of the NeoPixel library, and I was using the goggles example.
In file included from /usr/share/arduino/hardware/arduino/cores/arduino/Stream.h:26:0,
                 from /usr/share/arduino/hardware/arduino/cores/arduino/HardwareSerial.h:28,
                 from /usr/share/arduino/hardware/arduino/cores/arduino/Arduino.h:193,
                 from /home/xmanj/arduino/sketchbook/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.h:23,
                 from sketch_sep03b.ino:1:
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:32:0: warning: "BIN" redefined [enabled by default]
 #define BIN 2
In file included from /usr/lib/avr/include/avr/iotn85.h:38:0,
                 from /usr/lib/avr/include/avr/io.h:340,
                 from /usr/lib/avr/include/avr/pgmspace.h:88,
                 from /usr/share/arduino/hardware/arduino/cores/arduino/Arduino.h:8,
/usr/lib/avr/include/avr/iotnx5.h:55:0: note: this is the location of the previous definition
 #define BIN     7
sketch_sep03b.ino:28:75: error: ‘NEO_KHZ400’ was not declared in this scope
joshlucy
