Adafruit_NECremote lib not working with TSOP38238 and mini remote ctrl
by eduino on Sun Feb 24, 2013 8:20 pm
Hey there,
My project is a servo-enabled, remote controllable heater button (and later on a full-fledged thermostat) since it tends to be pretty cold in my room during winter. But for now, I can't read the codes sent by the remote in the Serial monitor :'(
I am using a UNO board, a TSOP38238 and a mini remote controller bought from adafruit. I've downloaded the lib from Github (https://github.com/adafruit/Adafruit-NE ... ol-library) but I can't get the listener example working using a standard setup (sensor output to pin 2, sensor ground to GND and sensor vcc to +5V). Serial monitor endlessly display the "Timed out waiting!" error message.
I was not sure if IR reception was OK so I plugged in a LED to see if it blinks when receiving signal from the sensor and it does, hence the problem lies elsewhere ...
Picture:
http://imgur.com/uqTL7ld
Code:
  This is an example for the Adafruit NEC Remote Control
  Designed specifically to work with the Adafruit NEC Remote Control
----> http://www.adafruit.com/products/389
  and IR Receiver Sensor
----> http://www.adafruit.com/products/157
  These devices use IR to communicate, 1 pin is required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include "Adafruit_NECremote.h"
// Connect a 38KHz remote control sensor to the pin below
#define IRpin 2
Adafruit_NECremote remote(IRpin);
void setup(void) {
  Serial.begin(9600);
  Serial.println("Ready to decode IR!");
int lastcode = -1;
void loop(void) {
  // You can set the listen() time out to 'n' seconds
  int c = remote.listen(1); // seconds to wait before timing out!
  // Or you can wait 'forever' for a valid code
  //int c = remote.listen(); // Without a #, it means wait forever
  if (c >= 0) {
    Serial.print("Received code #");
    Serial.println(c, DEC);
    lastcode = c;
  } else if (c == -3) {
    Serial.print("Repeat (");
    Serial.print(lastcode);
    Serial.println(")");
  } else if (c == -2) {
    Serial.println("Data error");
  } else {
    Serial.println("Timed out waiting!");
Thanks for your help,
E.
eduino
Re: Adafruit_NECremote lib not working with TSOP38238 and mini remote ctrl
by beercannon on Tue Feb 26, 2013 2:48 pm
See my thread here:
viewtopic.php?f=25&t=37457
You may be having the same problem I was.. that particular IR sensor is one that strips the 38k pulse and reports only the signal on/off pulses.
beercannon
