Adafruit MCP23017 i2c library with Arduino Due (IDE 1.5.2)
by Dewy on Sat Mar 09, 2013 12:11 pm
Just a silly i2c (and Due) noob question.
I'm trying to use the Adafruit MCP23017 library with the Arduino Due (IDE 1.5.2)
Here's the problem, the IDE automatically switches configs/backend between AVR and ARM during board select.
Select the Arduino Mega2560 for example and the library works just fine. (As advertised.) :)
However if you select the Arduino Due as the target device the back-end changes and the library no longer works.
So my noob question question is; can I copy the headers from the AVR toolchain into a sketch sub-folder labeled "avr" and have it work safely?
It does compile this way, but when it got around to calling for the fuse.h file I got concerned, stopped short of uploading it, and clicked by here for some skilled advice.
The library calls for avr/pgmspace.h...
pgmspace.h calls for:
avr/common.h
avr/fuse.h
avr/io.h
avr/lock.h
avr/portpins.h
avr/sfr_defs.h
avr/version.h
Surely, such a mediation is not going to be that simple.
Any advice?
Dewy
Re: Adafruit MCP23017 i2c library with Arduino Due (IDE 1.5.2)
by adafruit_support_rick on Sat Mar 09, 2013 4:28 pm
The Due is a completely different processor architecture; totally unrelated to the AVR. Our libraries have to be ported before they will work on a Due. This is something that we're working on right now, but it's not necessarily a trivial task and it will take some time. All I can say is that we're trying to get through them all as quickly as we can.
by Dewy on Sun Mar 10, 2013 2:49 am
Thank you Driverblock, I was nearly certain that was going to fail.
BTW, dose the ARM actually use fuses? And if so can one be bricked by such misconceptions?
Dewy
by adafruit_support_rick on Sun Mar 10, 2013 1:06 pm
Dewy wrote:BTW, dose the ARM actually use fuses? And if so can one be bricked by such misconceptions?
Good question. I just had a squint at the SAM3X datasheet. I didn't see anything that looked like a fuse. They have some "lock regions" in flash, and a "security bit" which can be set to prevent any external access to flash (so nobody can download and hack your executable).
So far, I haven't seen anything that can't be undone. Unsetting the security bit simply requires wiping the flash.
It looks like no bricking is possible, so go ahead - do yer worst! :wink:
by Dewy on Fri Mar 15, 2013 3:27 am
Thanks! I shall *surly-forth...
*surly = bikers only do one thing with a 'Sally'. >;)
Dewy
by adafruit_support_rick on Fri Mar 15, 2013 11:53 am
Odd. The bike in your avatar doesn't look like a Surly... :wink:
