Programmable 4 Coin Type Coin Slot error
by cld on Sun Mar 10, 2013 10:18 pm
I've been using this coin slot for about a month and it's been functioning really well. Today suddenly there it no longer works and the display says E3, some kind of error but for what? I can't find anything online or in the manual? Please help! I;ve tried everything I can think of and it seems as if this thing is just broken.
cld
Re: Programmable 4 Coin Type Coin Slot error
by adafruit_support_bill on Mon Mar 11, 2013 7:56 am
Is anything jammed? Are the coins still passing through? Have you tried going through the setup again?
by cld on Mon Mar 11, 2013 9:04 am
The coins pop back out the front, but I can't see to find any jams. I thought to run it through the setup again, but the E3 message that is up won't allow you to do anything. It seems like there's a sensor that's off somewhere- but seriously can't find which one.
cld
by cld on Mon Mar 11, 2013 9:19 am
i figured out the E2 message means that the area where the coin first passes through isn't lined up correctly, so i thought perhaps this E3 means that the second area where the coin passes through -on its way out- is jammed, but how can you tell/fix it? Does this thing just burnout after awhile?
cld
by adafruit_support_bill on Mon Mar 11, 2013 10:03 am
Do you know what kind of sensor is in that area? I don't have one here now to check, but I can take a look later today.
by cld on Mon Mar 11, 2013 10:24 am
Can't see what controls that section, but please do take a look and get back to me. I have a feeling this may just be a cheap electronic fail.
cld
by cld on Sat Mar 16, 2013 2:27 pm
Can someone get back to me about this?
cld
by adafruit_support_bill on Sun Mar 17, 2013 6:27 am
Hi, I tore one down and looked inside. All the sensors are in that first sensor module. The next section of the coin path is the solenoid that diverts the coin path. There are two wires coming from the solenoid coil that plug into the edge of the main circuit board. Make sure that the connector on that has not come loose.
by cld on Tue Mar 26, 2013 8:06 pm
I took it apart and it doesn't seem like it's come loose. Can you sort out what the E3 error means?
cld
by adafruit_support_bill on Wed Mar 27, 2013 5:48 am
Are you getting the error at power-up, or only when a coin passes through? I believe it is a sensor error, but there is not much information on these units.
