Adafruit Fingerprint scanner
by GuruShiva on Mon Mar 18, 2013 4:33 am
Hello, I have a Fingerprint scanner and as we know it, it does have very short wires that causes unstable connection, However, in the tutorial I see that it has been soldered to a header am I right? What is a better way for making a stable connection with the scanner. Much appreciated.
GuruShiva
Re: Adafruit Fingerprint scanner
by adafruit_support_bill on Mon Mar 18, 2013 6:32 am
Soldering the wires to some header pins makes a very good connection. You can also use some solid-core wire. But I find that the headers work best.
by GuruShiva on Tue Mar 19, 2013 7:40 am
Thank you!. Is there any way you can change the wires if you have messed with?. Much appreciated.
GuruShiva
by adafruit_support_bill on Tue Mar 19, 2013 7:53 am
You can just trim them back, strip off some more insulation and re-solder.
cron
