Micro SD breakout board
by idanb on Mon Mar 18, 2013 7:11 pm
I'm facing a bit of a problem. I bought the Micro SD breakout board and it's not working I'm receiving the following error when using the CardInfo test:
initialization failed. Things to check:
* is a card is inserted?
* Is your wiring correct?
* did you change the chipSelect pin to match your shield or module?
I'm using the following hardware:
* Transcend 4GB Micro SDHC
* Arduino MEGA ADK for Android
I wanted to upload the pics of the system but I receive an error even though I am using JPEG.
Need your help
idanb
Re: Micro SD breakout board
by adafruit_support_rick on Mon Mar 18, 2013 7:40 pm
Reduce the size of your jpegs. 800 x 600 is usually a good size, so long as we can still see details.
by idanb on Tue Mar 19, 2013 2:49 am
here goes:
idanb
by adafruit_support_rick on Tue Mar 19, 2013 10:58 am
Hard to see, but it looks like none of the connections on the breakout board are soldered? It won't work that way. You should solder on the header strip, insert that in the breadboard, and then jumper to the breadboard.
by timi on Wed Mar 20, 2013 1:04 pm
i am using a similar sd board on my arduino mega with SD. h but with CS on pin 53
timi
by timi on Wed Mar 20, 2013 1:29 pm
my example code for which I use the sd card http://pastebin.com/NKGjXL0P
timi
