i Have got flora from your website but when i connect it to PC it says usb not recognized and i have try this to 4 computers but the problem is same
please help me in that
Honey
usb not recognized
Re: usb not recognized
First, try connecting with another USB cable. Sometimes that does the trick.
If not, what operating system are you using?
- skelhoney
I have already tried to connect with 3 or 4 usb cables but it still not working and i am using windows 7
as i already said before i try it with many computers
thanks
thanks
- skelhoney
Does anything change in the Device Manager when you plug/unplug the Flora?
- skelhoney
Dear i know how to install driver i am already using arduino uno and mega. i think there is the problem in the device can you please replace it ?
I didn't ask if you'd installed the driver. I asked if anything shows up in the Device Manager when you connect and disconnect the Flora. That's a debugging step that gives us information about the state of the firmware and bootloader.
If the Flora's bootloader is corrupted, your computer will recognize the Flora as a basic USB device but won't be able to do anything with it. If the firmware is corrupted you might see a raw device ID. If there's a hardware fault, you won't see any change at all.
We'd like to nail down the nature of the problem and provide you an immediate fix if one exists, rather than making you wait for the shipping time that comes with an RMA. If the hardware is indeed beyond fixing, we'll get you a new one.
- skelhoney
HI... when i connect flora nothing is happening . even do not start to install drivers. there is nothing is happening in the device manager too.
sending you video please check the below link
https://www.youtube.com/watch?v=fj8RLdu9UXE
Okay, that sounds like a hardware fault. Send a message to [email protected] with a link to this thread and they'll get you a replacement.
- ktigger05
Hello, I am having the same issues, except when I connect the Flora device, it does recognize that something is plugged in, but i gives this error in Device manager "Unknown USB Device (Device Descriptor Request Failed).
It was working well before, but I had to unplug the board to install some NeoPixels. Once I tried plugging it back in it began giving me this error. Since then I have disconnected everything, and it is still giving me this error.
Try deleting the driver and COM port, then reinstalling from scratch. It's possible that the port didn't get shut down properly when you disconnected the Flora.
- pattoj79
H, I have a similar issue;
I have 2 Flora's and 1 works fine and is appearing as it should be in the Device manager as COM3, I can upload to it as I should.
The 2nd one does nothing when I plug it in, however, when I push the reset button on the flora the computer recognizes it and puts it on COM4 and then disappears again once the reset process is complete. I can't upload to it or do anything.
Any ideas how to rectify this?
- pattoj79
Update
I found the solution eventually on another forum topic below.
http://forums.adafruit.com/viewtopic.php?f=24&t=38847
From Arduino program press upload and whilst compiling, I pressed the reset button and it uploaded the sketch and also now recognizes the Flora on the COM port again.
So all good....... I was in panic mode for a while there....
- ktigger05
Same, that's what I had to do as well.
- g t
I tries loading the strandtest and my LED doesn't even do the test at all....not sure what is going on this is after my flora connect and it said USB not recognized and I tries doing a reset button...Nothing is lighting up the LED stripe. Please help.
