CC3000 SmartConfig stops working
by CS Gaertner on Fri Oct 04, 2013 12:46 pm
The CC3000 SmartConfig isn't responding any more. It used to work, after testing the 2(two) breakout boards. Everything else still works fine, but after running a bunch of other sketches, which just connect to the network and broadcast UDP-Messages it just stopped working. Can't get SmartConfig running on both breakout boards anymore. It just times out. Tried the Android-App and the Java-Applet.
Please Help... :(
CS Gaertner
Re: CC3000 SmartConfig stops working
by adafruit_support_mike on Sat Oct 05, 2013 1:56 am
What kind of hardware are you using along with the CC3000?
Post a photo of your setup and we'll see if that offers any clues.
by CS Gaertner on Sat Oct 05, 2013 3:59 am
Hardware is an Uno and some Jumperwire. Photo will follow.
CS Gaertner
by CS Gaertner on Mon Oct 07, 2013 4:47 am
Wiring... doublechecked connections, changed jumper wires, changed arduino.
SerialOutput of SmartConfig Sketch:
RX Buffer : 131 bytes
TX Buffer : 131 bytes
Free RAM: 550
Initialising the CC3000 ...
Firmware V. : 1.19
MAC Address : 0x08 0x00 0x28 0x57 0x36 0x0D
Deleting old connection profiles
Waiting for SmartConfig connection (~60s) ...
Got smart config data
Timed out waiting to connect
SmartConfig failed
Wiring1
CS Gaertner
by georgehawkins on Mon Oct 07, 2013 2:13 pm
Exactly the same thing happened to me - it fails at exactly the same point:
I.e. it clearly appears to receive the Smart Config data but then fails to be able to use it to connect.
The module still works fine and successfully connects to the network if I don't use Smart Config and instead hard code the SSID and password in my sketch.
I wasn't actually changing things about with my Arduino/CC3000 setup when things first went wrong - it just stopped working one day.
As I'm using the breakout board connected up via a breadboard, rather than the shield version, I assumed one of my wires had come loose (though this seemed less likely later when I could prove to myself that everything worked if I used the non-Smart Config approach).
I checked all my wiring and actually pulled everything out and rewired it - however as pointed out the fact that it works with the hardcoded SSID and password approach makes me think it's not a wiring problem. And the fact that it seems to be able to receive the Smart Config data suggests there isn't an issue with being able to monitor wifi channels.
So why making a connection with the received data should timeout I don't know.
georgehawkins
by adafruit_support_rick on Mon Oct 07, 2013 3:44 pm
SmartConfig is still kind of experimental at this point.
by eliavg9 on Wed Oct 30, 2013 2:37 am
I'm having the same issue (I'm using the shield with an Uno).
Did you manage to solve it?
eliavg9
by adafruit_support_rick on Wed Oct 30, 2013 7:13 am
I don't have any new information on this issue. Make sure your CC3000 library and your smart config app are both up-to-date
by eliavg9 on Wed Oct 30, 2013 3:45 pm
Maybe I have a mistake in code?
Can you look at this, tell me if I'm doing anything wrong:
if (!cc3000.begin(false,true))
    // No profile found!
    cc3000.deleteProfiles();
    // Deleted profiles to make sure there's no garbage
    if (!cc3000.startSmartConfig(false))
      cc3000.begin();
      if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY))
        while(1); //Error
eliavg9
by adafruit_support_rick on Thu Oct 31, 2013 7:27 am
That is wrong. Do not call connectToAP when using smart config.
You are calling begin twice.
Your first call to begin tells the cc3000 to use stored smart config data. After that, you call deleteProfiles, which deletes any stored information before it can be used by startSmartConfig.
Try this:
  /* Initialise the module, deleting any existing profile data (which */
  /* is the default behaviour)  */
  Serial.println(F("\nInitialising the CC3000 ..."));
  if (!cc3000.begin(false))
    Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
    while(1);
  /* Try to use the smart config app (no AES encryption), saving */
  /* the connection details if we succeed */
  Serial.println(F("Waiting for a SmartConfig connection (~60s) ..."));
    Serial.println(F("SmartConfig failed"));
    while(1);
  Serial.println(F("Saved connection details and connected to AP!"));
by CS Gaertner on Thu Oct 31, 2013 10:45 am
And another b[y]tes the dust.... :(
This time it's a shield on a mega... only one left on my bench.
Has been working since 2 Weeks with a hundreds of tries. I ported the SmartConfig paket sending to Windows Library for use in Delphi, so i testet SmartConfig a lot and just now it stops its work and never comes back. As befor on the breakout board, everthing else is running fine.
Hello, CC3000!
Free RAM: 6202
Firmware V. : 1.19
MAC Address : 0x08 0x00 0x28 0x57 0x33 0x86
SmartConfig failed
CS Gaertner
by adafruit_support_rick on Thu Oct 31, 2013 11:33 am
Try running one of the other sample sketches, like buildtest, which should clear out all the saved connection data.
by CS Gaertner on Thu Oct 31, 2013 12:01 pm
Already tried... Library is up to date. Buildtest works... as everything else but the smart config.
CS Gaertner
by adafruit_support_rick on Thu Oct 31, 2013 12:36 pm
Are you running the smartConfigCreate or the smartConfigReconnect example?
by CS Gaertner on Thu Oct 31, 2013 12:40 pm
Current sketch is smartConfigCreate.
CS Gaertner
