Adafruit Motorshield V2 instantiating
by Techniker2013 on Mon Oct 28, 2013 9:30 am
Hi everyone,
for my projekt at the technikal college I need to work with arduino and I have some troubles with it. I want to use the following componets to drive 2 stepper motors:
Arduino Uno
2x pd2-013-42 bipolar stepper motors
I found an example for using 2 stepper motors and I tried to use it for my projekt, but sadly it didn´t worked as I thought it would.
The sketch I used is the AFMotor_MultiStepper with Accelstepper and AFMotor library, if I understand it right, it should make an objekt that the AccelStepper can use.
My problem at the moment is, that I don´t know if my code is wrong or if something else doesn´t work as I intended it would.
So far i could run it with the normal Stepper library to let it turn clock- and counterclockwhise, but I couldn´t figure out why it doesn´t work with this sketch.
The motor doesn´t take much current only about 0.05 A but it should take about 0.6 A, so no motorcoil is powered.
I´m new to Arduino and any kind of help would be appritiated.
Here is the code I used:
#include <AccelStepper.h>
#include <AFMotor.h>
// Objekt mit (200 Schritten, an Port 1) z.B.
AF_Stepper motor1(200, 1);
AF_Stepper motor2(200, 2);
// SINGLE (eine Spule), DOUBLE (zwei Spulen), INTERLEAVE (wechsel zwischen SINGEL u. DOUBLE)
//für doppelte Auflösung aber halbe Geschwindigkeit, MICROSTEP (mit PWM (Pulsweitenmodulation) für ruhige Bewegung des Motors)
// Methoden für Vorwärts und Rückwärtsbewegung der Motoren
void forwardstep1() {
  motor1.onestep(FORWARD, DOUBLE);
void backwardstep1() {
  motor1.onestep(BACKWARD, DOUBLE);
void forwardstep2() {
  motor2.onestep(FORWARD, DOUBLE);
void backwardstep2() {
  motor2.onestep(BACKWARD, DOUBLE);
// Motor Ports nutzbar für Accelstepper machen
AccelStepper stepper1(forwardstep1, backwardstep1);
AccelStepper stepper2(forwardstep2, backwardstep2);
void setup()
    stepper1.setMaxSpeed(20.0);
    stepper1.setAcceleration(10.0);
void loop()
    stepper1.run();
Techniker2013
Re: Adafruit Motorshield V2 instantiating
by adafruit_support_bill on Mon Oct 28, 2013 10:15 am
AF_Motor is the library for the older motor shield. For the V2 shield you need the V2 library.
https://github.com/adafruit/Adafruit_Mo ... V2_Library
Also, make sure you are using the Adafruit-modified version of AccelStepper.
https://github.com/adafruit/AccelStepper
by Techniker2013 on Wed Oct 30, 2013 5:26 am
Thank you for the help, i used the wrong library like you said.
Could you send me a link for the modified version of the Accelstepper reference, or does it have the same programming commands, like the common one?
Yours sincerely, Techniker2013
Techniker2013
by adafruit_support_bill on Wed Oct 30, 2013 6:34 am
It may be a few revs behind the current release, but the API should be basically the same. The .h file is the ultimate reference.
