2.2 TFT W/ILI9340C
2.2 TFT W/ILI9340C
by IrvinPoncePerez on Tue Oct 29, 2013 6:23 pm
Hello Adafruit!
I Have the product http://www.adafruit.com/products/1480 and an Arduino Uno R3, my question is, how can i wired this?
IrvinPoncePerez
Re: 2.2 TFT W/ILI9340C
by adafruit_support_rick on Tue Oct 29, 2013 6:34 pm
You can follow the wiring in the old tutorial
http://learn.adafruit.com/2-2-tft-display
by IrvinPoncePerez on Thu Nov 07, 2013 1:39 am
Hello Adafruit!
I have Problems with my 2.2" TFT w/ILI9340C. I added the libraries Adafruit_ILI9340 and AdafruitGFX, I can compile and upload the sketch graphictest without problem.
Arduino IDE.PNG (26.61 KiB) Viewed 293 times
And I had connect the Arduino Board Uno like indicated the sketch.
SCK -> pin 13
MISO -> pin 12
MOSI -> pin 11
CS -> pin 10
RST -> pin 9
D/C -> pin 8
But, my display is white, what's the problem?
IrvinPoncePerez
by adafruit_support_rick on Thu Nov 07, 2013 8:42 am
You need to add a jumper wire between VIN and BL to power the backlight.
I can't see any of your solders in the picture - if you can post a picture of those, we can check to see that they are solid.
I can't see how you have the header pins installed, but it looks as if the black plastic is on top of the board, and the long side of the pins are pointing upwards? If so, the pins on the bottom of the board may not be long enough to make contact with the breadboard.
Please post photos of both sides of the display board.
