Operating system is Windows 8.1. I had an issue with data corruption @ 115,200; reduced serial data rate to 9,600. Corruption went away.
* Simple WiFi weather station with Arduino, the DHT22 sensor & the CC3000 chip
* Part of the code is based on the work done by Adafruit on the CC3000 chip & the DHT11 sensor
* Writtent by Marco Schwartz for Open Home Automation
// Include required libraries
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include "DHT.h"
#include<stdlib.h>
// Define CC3000 chip pins
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// WiFi network (change with your settings !)
#define WLAN_SSID "Oceans" // cannot be longer than 32 characters!
#define WLAN_PASS "reddog60"
#define WLAN_SECURITY WLAN_SEC_WPA2 // This can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
// DHT11 sensor pins
#define DHTPIN 7
#define DHTTYPE DHT22
// Create CC3000 & DHT instances
DHT dht(DHTPIN, DHTTYPE);
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIV2);
// Local server IP, port, and repository (change with your settings !)
uint32_t ip = cc3000.IP2U32(192,168,2,7);
int port =8887;
String repository = "/wifi_weather_station/";
void setup(void)
// Initialize DHT sensor
dht.begin();
Serial.begin(9600);
// Initialise the CC3000 module
if (!cc3000.begin())
while(1);
// Connect to WiFi network
cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
Serial.println("Connected to WiFi network!");
// Check DHCP
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(100);
/* Display the IP address DNS, Gateway, etc. */
while (! displayConnectionDetails()) {
delay(1000);
void loop(void)
// Measure the humidity & temperature
float h = dht.readHumidity();
float t = dht.readTemperature();
// Transform to String
String temperature = String((int) t * 9/5 +32);
String humidity = String((int) h);
// Print data
Serial.print("Temperature: ");
Serial.println(temperature);
Serial.print("Humidity: ");
Serial.println(humidity);
Serial.println("");
// Send request
String request = "GET "+ repository + "sensor.php?temp=" + temperature + "&hum=" + humidity + " HTTP/1.1";
send_request(request);
// Update every second
delay(2000);
// Function to send a TCP request and get the result as a string
void send_request (String request) {
// Connect
Serial.println("Starting connection to server...");
Adafruit_CC3000_Client client = cc3000.connectTCP(ip, port);
// Send request
if (client.connected()) {
delay(500);
client.println(request);
client.println(F(""));
Serial.println("Connected & Data sent");
else {
Serial.println(F("Connection failed"));
while (client.connected()) {
while (client.available()) {
// Read answer
char c = client.read();
Serial.println("Closing connection");
Serial.println("");
client.close();
@brief Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
Serial.println(F("Unable to retrieve the IP Address!\r\n"));
return false;
else
Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
Serial.println();
return true;
I can display website pages in localhost with the default install of WAMPServer.
Also, I found that if I create two text files --hum_data.txt and temp_data.txt; the server displays the Wifi-weather-station.htm. There is no updating of the two txt files.
