https://github.com/adafruit/Adafruit-LE ... ck-Library
Can anyone tell me how large this library is please?
My arduino sketch is already "Binary sketch size: 27,576 bytes (of a 32,256 byte maximum)" and I am worried this will be too much.
All it needs to display is a couple of smiley faces.
LED backpack library
- adafruit_support_rick
Re: LED backpack library
Looks like it's a little over 4K. You can delete the parts of the .cpp file you don't need - that may help.
How libraries affect the size of sketches may often vary depending on how they were written and how they are used.
My advice - Try it. If it's too large, remove it from the sketch* and figure out another way to do what you need. Or...remove parts that are unneeded, as Rick stated.
*(More specifically, I'd make a second copy of the sketch with a slightly different name and use that file to experiment with the library and try any other changes. If it works, start using that sketch. If it doesn't work....you still have the original copy.)
- pburgess
Also, in a pinch, you could try adapting the Trinket 'Space Invader Pendant' code to the Uno or whatever board you're using:
http://learn.adafruit.com/trinket-slash ... ource-code
Replace all 'TinyWireM' occurrences with 'Wire' (the standard Wire library), and you can disregard all the power, sleep, interrupt and direct-register code.
