Bluefruit doesn't seem to turn on with less than 5v
drewbaumann
Post by drewbaumann »
First off my apologies for coming off like a total noob, because I am, but I seem to be having trouble powering a Bluefruit EZ-Key http://www.adafruit.com/products/1535.
I was attempting to power it with a https://www.sparkfun.com/products/10161 ... fgodnT0Axw without any luck. I took a multimeter to the single cell charger and saw that it was roughly 4.2-4.4v. I thought that was odd since the Bluefruit requires 3-16v. However I did get a response from it by connecting my trinket's 5v to the vin and grounding it.
Unfortunately that sparkfun product got fried while trying to solve the mystery so I have ordered a http://www.adafruit.com/products/259. Hopefully this will have more desirable results.
I'm not sure if this is standard, if I made a rookie mistake, or I have a defective board. I would just like to build something cool at the end of the day (and by end of the day I mean when all my parts come in).
Re: Bluefruit doesn't seem to turn on with less than 5v
I was attempting to power it with a ...
Just to be sure: Are you trying to power it with just the charger, or is there a LiPo cell connected as well?
drewbaumann
Just the portion that connects to the board.
So you had a fully charged LiPo connected to the charger and the EZ-Key was connected to the load outputs of the charger?
I'm not familiar with the SparkFun charger you linked, but using our USB Lion/LiPoly charger in that configuration should easily power the EZ-Key.
drewbaumann
A battery was not connected. Other than that you are correct.
Without a battery connected, many chargers will not work. Not positive about the Sparkfun charger, but our USB LiPo charger needs a battery connected to work properly. It is designed primarily to charge batteries and the output voltage and current regulation are based on the detected battery level.
drewbaumann
Great. I will try that once all the parts arrive in a week or so.
