I followed kkolbo's instructions http://forums.adafruit.com/viewtopic.php?f=22&t=39012 here to install the Arduino IDE. The only change I made was to install the latest version, 1.0.5.
This seemed to work fine and I now have a nice shortcut to run the IDE from my desktop. However, I can't connect to my Flora via the serial port. I'm having the same problem that attlebish posted here http://forums.adafruit.com/viewtopic.ph ... tu#p198789. In the Tools tab, my Serial Port is greyed out and I can't use it at all. I've tried the solutions posted in that forum, doing
sudo usermod -a -G dialout YOURUSERNAMEHERE
ls -la /dev/ttyACM0
ls: cannot access /dev/ttyACM0: No such file or directory
SUBSYSTEMS==”usb”,ATTRS{idVendor}==”239a”,ATTRS{idProduct}==”0004″,MODE=”0660″,GROUP=”plugdev”,ENV{ID_MM_DEVICE_IGNORE}=”1″
SUBSYSTEMS==”usb”,ATTRS{idVendor}==”239a”,ATTRS{idProduct}==”8004″,MODE=”0660″,GROUP=”plugdev”,ENV{ID_MM_DEVICE_IGNORE}=”1″
service udev restart
stop: Rejected send message, 1 matched rules; type="method_call", sender=":1.83" (uid=1000 pid=3327 comm="stop udev ") interface="com.ubuntu.Upstart0_6.Job" member="Stop" error name="(unset)" requested_reply="0" destination="com.ubuntu.Upstart" (uid=0 pid=1 comm="/sbin/init")
start: Rejected send message, 1 matched rules; type="method_call", sender=":1.84" (uid=1000 pid=3324 comm="start udev ") interface="com.ubuntu.Upstart0_6.Job" member="Start" error name="(unset)" requested_reply="0" destination="com.ubuntu.Upstart" (uid=0 pid=1 comm="/sbin/init")
Thanks for any help you can provide! - Fuzzy
