Wave Shield with Rotary Encoder
by adamr1 on Mon Feb 17, 2014 8:02 pm
Can you use a wave shield and a rotary encoder with interrupts. I want to use the rotary encoder to pick a song to play by the wave shield. Documentation that I found about rotary encoders says to use pin 2 and 3 on an uno but the wave shield has those hard wired. In a perfect world, if a song were playing on the wave shield, and you turned the encoder, it would stop the current song and play the next one. From what I understand, the wave shield uses interrupts to "play in the background?" So there will be a conflict, right? And I wont be able to use a rotary encoder? Thanks
adamr1
Re: Wave Shield with Rotary Encoder
by adafruit_support_mike on Mon Feb 17, 2014 11:55 pm
I think the WaveHC library does use interrupts, but you can poll the encoder during the
while ( wave.isplaying() ) {
loop.
A couple of digital reads won't take long. You'll get the same overall effect, even though the code doesn't respond quite as immediately as it would with an interrupt.
by adamr1 on Tue Feb 18, 2014 8:38 am
ok thanks, I will try that.
adamr1
