Hello, I am new to using motor shields and micro controller. I was wondering if the Adafruit 16-Channel 12-bit PWM/Servo Driver: http://learn.adafruit.com/adafruit-16-c ... d/overview is compatible with the Arduino Mega 2560: http://arduino.cc/en/Main/arduinoBoardM ... yUIVPmwLYg. If so, is there a connection diagram for the Arduino Mega 2560 similar like the connection diagram for Arduino Uno that the website provides.
Thanks for the help!
[Adafruit 16-Channel 12-bit PWM/Servo Driver] Microcontrolle
Re: [Adafruit 16-Channel 12-bit PWM/Servo Driver] Microcontr
Yes, that shield will work with the Mega 2560.
Instead of making a new post I will post here.
I was wondering how much voltage will this motor shield take in. Can this motor shield take 12V from an adaptor? If so, can I reduce the voltage from 12V to 5-6V with PWM? Because right now I have an adapter that supplies 12V and 5A (https://www.adafruit.com/products/352). And I want to use it for the micro controller (https://www.adafruit.com/products/1411#Description) to power 6 Servo Motors. But the motor shield specified that the servo motor runs at 5 or 6V. So I was wondering would that be a problem using a 12V adaptor on a motor shield that wants only 5-6V to power servo motors.
Also I am wondering, if I receive 12V from the adapter to the motor shield will there be a voltage drop? Say from 12V on the adapter to 10V once it is received from the motor shield. Because I read a post about there being a voltage drop from the H-bridge from this link: http://forums.adafruit.com/viewtopic.php?f=31&t=26873
