2 different Voltages measured with INA219
- wweetts
Is it possible to measure 2 different voltages (12V and 24V) with the INA219 when I take out the 100 Ohm resistor?
Re: 2 different Voltages measured with INA219
It's technically possible, but would be complicated.
You'd only get a direct reading for the lower voltage. Then you'd get a value for the difference between the two voltages, calculated as a current through the sense resistor. You'd have to go through a fairly complicated set of equations to configure the INA219 so it would give you reasonable output values, then you'd have to convert those back to a voltage in the microcontroller.
It would be much easier to use a regular ADC.
