Mike sent me a display format for displaying time and date on the screen.
It was sprintf(charBuff, "%0d", numbertoconvert);
Now I need to convert a floating point number to a displayable format.
I've tried a number of variations of
sprintf(charBuff, "%xxf", floatingpointnumber);
where xx is 0, 1, 0.1, 1.1, 2, etc.
All I seem able to display is ?
I assume that the ? means that the format can't be converted.
my floating point numbers are x.x and xx.x
Sounds pretty simple.
A Wikipedia search on sprint hasn't gotten me any help.
Any ideas?
Display formatting for RA8875
- pkourany
Re: Display formatting for RA8875
bradv, the best reference for sprintf is printf! This a good reference: http://www.cplusplus.com/reference/cstdio/printf/
In your case, you would want to use sprintf(charBuff, "%4.1f", floatingpointnumber);
The 4 specifies the minimum number of digits to print (smaller numbers are padded with spaces)
The 1 specifies the number of digits to print on the right of the decimal point
Hopefully, that works for you :)
- bradv
Tried your suggestion.
I stubbed out most of the code to isolate this section and keep getting the same answer.
The function prints CharBuff to the screen correctly.
CharBuff actually contains a '?'.
Here's the snippet.
PHnow is defined as "float PHnow".
Great reference.
Thanks.
Here's the snippet.
PHnow = 5.4;
if (PHnow < (PHSet[ZonePtr] + 0.2) && PHnow > (PHSet[ZonePtr] - 0.2))
tft.fillRect(620, 140, 120, 50, RA8875_CYAN); // draw PH Box
tft.textTransparent (RA8875_BLACK);
tft.textSetCursor (645,140);
sprintf(CharBuff,
"%4.1f", PHnow);
tft.textWrite (CharBuff);
else
tft.fillRect(620, 140, 120, 50, RA8875_RED); // PH Box
tft.textTransparent (RA8875_WHITE);
sprintf(CharBuff,
"%4.1f", PHnow);
Great reference.
Thanks.
