I want to use this accelerometer in one of my projects. The datasheet says it supports two programmable interrupts, and there seem to be two pins for that externally on the breakout board. I'm a bit of a noob, though. How do I program these interrupts? It doesn't look like the library supports this.
All I want to do is have one go high if there's motion so that I can wake up my arduino.
LSM303 Accelerometer Interrupts?
Re: LSM303 Accelerometer Interrupts?
The interrupt capabilities of the LSM303 are pretty powerful. But I'm not aware of any libraries that support it.
The documentation of the interrupt registers starts on page 29:
http://www.adafruit.com/datasheets/LSM303DLHC.PDF
It looks like you need to enable one or more of the various interrupt modes in the configuration register, specify one or more sources in the source register then set the threshold and duration in their respective registers.
- richlangston007
Yeah, my reading is I need program a 0, and then all 1's, into INT1_CFG_A (30h).
I guess I need to use this library function, with the appropriate register values...
void Adafruit_LSM303::write8(byte address, byte reg, byte value)
Wire.beginTransmission(address);
Wire.write(reg);
Wire.write(value);
Wire.endTransmission();
Wire.write(reg);
Wire.write(value);
That would be the function to use to write the registers.
I believe you would also need to set the source, threshold and duration registers to generate interrupts based on detected motion.
