Good afternoon, two months ago aproximandamente buy a thermal printer.
Yesterday I started testing with the libraries and examples, and these are the results:
Any idea what is happening?
The power supply I'm using is this:
Thank you!
Thermal printer barcode problem
- Franklin97355
Re: Thermal printer barcode problem
What code are you running and just what are we looking at in the top picture? I don't have a printer so I don't know what it should look like. Have you tried pulling out about 6 inches of paper and trying again in case the paper is bad? It also says you need 1.5 amps of power so your power supply should be OK.
This is the code i am using:
This is an Arduino library for the Adafruit Thermal Printer.
Pick one up at --> http://www.adafruit.com/products/597
These printers use TTL serial to communicate, 2 pins are required.
Adafruit invests time and resources providing this open source code.
Please support Adafruit and open-source hardware by purchasing products
from Adafruit!
MIT license, all text above must be included in any redistribution.
// If you're using Arduino 1.0 uncomment the next line:
#include "SoftwareSerial.h"
// If you're using Arduino 23 or earlier, uncomment the next line:
//#include "NewSoftSerial.h"
#include "Adafruit_Thermal.h"
#include "adalogo.h"
#include "adaqrcode.h"
#include <avr/pgmspace.h>
int printer_RX_Pin = 5; // This is the green wire
int printer_TX_Pin = 6; // This is the yellow wire
Adafruit_Thermal printer(printer_RX_Pin, printer_TX_Pin);
void setup(){
Serial.begin(9600);
pinMode(7, OUTPUT); digitalWrite(7, LOW); // To also work w/IoTP printer
printer.begin();
// The following function calls are in setup(), but do not need to be.
// Use them anywhere! They're just here so they're run only one time
// and not printed over and over.
// Some functions will feed a line when called to 'solidify' setting.
// This is normal.
// Test inverse on & off
printer.inverseOn();
printer.println("Inverse ON");
printer.inverseOff();
// Test character double-height on & off
printer.doubleHeightOn();
printer.println("Double Height ON");
printer.doubleHeightOff();
// Set text justification (right, center, left) -- accepts 'L', 'C', 'R'
printer.justify('R');
printer.println("Right justified");
printer.justify('C');
printer.println("Center justified");
printer.justify('L');
printer.println("Left justified");
// Test more styles
printer.boldOn();
printer.println("Bold text");
printer.boldOff();
printer.underlineOn();
printer.println("Underlined text ");
printer.underlineOff();
printer.setSize('L'); // Set type size, accepts 'S', 'M', 'L'
printer.println("Large"); // Print line
printer.setSize('M');
printer.println("Medium");
printer.setSize('S');
printer.println("Small");
printer.println("normal\nline\nspacing");
printer.setLineHeight(50);
printer.println("Taller\nline\nspacing");
printer.setLineHeight(); // Reset to default
// Barcode examples
printer.feed(1);
// CODE39 is the most common alphanumeric barcode
printer.printBarcode("ADAFRUT", CODE39);
printer.setBarcodeHeight(100);
// Print UPC line on product barcodes
printer.printBarcode("123456789123", UPC_A);
// Print the 75x75 pixel logo in adalogo.h
printer.printBitmap(adalogo_width, adalogo_height, adalogo_data);
// Print the 135x135 pixel QR code in adaqrcode.h
printer.printBitmap(adaqrcode_width, adaqrcode_height, adaqrcode_data);
printer.println("Adafruit!");
printer.feed(1);
printer.sleep(); // Tell printer to sleep
printer.wake(); // MUST call wake() before printing again, even if reset
printer.setDefault(); // Restore printer to defaults
please provide the adafruit order # with your purchase of the printer and thermal paper.
