I’m following this wiring diagram, found in the Adafruit learning system, to make work VS1053B with Arduino Micro:
https://learn.adafruit.com/adafruit-vs1 ... yer-wiring
And the following code found here:
http://votsh.files.BANNED.com/2014/0 ... ctions.pdf
When running the program I get in monitor: “VS1053 not found”
Has anyone go through the same problem?
Salutations,
Gonzalo
VS1053 not found on Arduino Micro
- adafruit_support_rick
Re: VS1053 not found on Arduino Micro
Please post clear, detailed pictures of the vs1053, showing your soldering.
Also post pictures showing your connections to the Micro
- gozaro
I have been looking at the wire and soldering and I think that I found the problem, Anyway a post images:
I found that the code mentioned didn’t work well at the Arduino 1.0.5. Seems that init() can not be use as a function, and the code to work needs to have the loop() function.
So I try to fix it, here is my version:
The problem comes when running the code. Seems that the mp3 files are not playing but the tone test works (musicPlayer.sineTest(0x44, 500)) so it makes me think that the problem is not because the wiring.
Any idea why mp3 files are not playing?
And also: why I need to open the monitor serial to get the tone test?
Sorry for my English.
#include <SPI.h>
#include <SD.h>
#include <Adafruit_VS1053.h>
#define CLK 9 // SPI Clock, shared with SD card
#define MISO 11 // Input data, from VS1053/SD card
#define MOSI 10 // Output data, to VS1053/SD card
#define RESET 13 // VS1053 reset pin (output)
#define CS 10 // VS1053 chip select pin (output)
#define DCS 8 // VS1053 Data/command select pin (output)
#define DREQ 4 // VS1053 Data request pin (into Arduino)
#define CARDCS 6 // Card chip select pin
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(RESET, CS, DCS, DREQ, CARDCS);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
iniciar();
void iniciar() {
// initialise the music player
if (!musicPlayer.begin()) {
Serial.println("VS1053 not found");
SD.begin(CARDCS); // initialise the SD card
musicPlayer.setVolume(20,20);
musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT); // DREQ int
musicPlayer.sineTest(0x44, 500); // Make a tone to indicate VS1053 is working
musicPlayer.playFullFile("SetUp.mp3");
You haven't initialized the SD card:Gozaro wrote:Any idea why mp3 files are not playing?
Because you are doing a wait for the Serial port to open in setup(). You can't get past this while loop until you open the Serial Monitor (the Micro and the Leonardo have the same processor):Gozaro wrote: And also: why I need to open the monitor serial to get the tone test?
while (!Serial) {
- gozaro
Thank you very much for your reply.
I already had SD.begin(CARDCS); in the iniciar() function.
I have put SD.begin(CARDCS); in the setup function and take out “while (!Serial)”
But it didn’t work. The new Code that uploaded is here:
When running the code in Arduino it makes a strange click but nothing else happens.
Any suggestion?
I had every thing working in the Arduino Uno before, I thinking dropping out Arduino Micro way and came back to Uno.
Do you think it will be easier to use Arduino Pro Micro?
#include <SPI.h>
#include <SD.h>
SD.begin(CARDCS);
while (!Serial) {
iniciar();
void iniciar() {
Any suggestion?
You are setting the player to use the DREQ interrupt. But you have DREQ defined as pin 4. The Micro does not have an external interrupt on pin 4. You must use pin 2 or 3 for DREQ.
- gozaro
Ok I have set up DREQ on pin 3 and I can hear the sineTest but the Mp3 is not playing...
OK, I tried duplicating your problem. Connecting reset to Pin 13 seems to confuse it. I had your code working like this:
#define RESET 9 // VS1053 reset pin (output)
#define DREQ 3 // VS1053 Data request pin (into Arduino)
#define CARDCS 4 // Card chip select pin
