I am trying to follow this tutorial to drive a small stepper motor via Raspberry PI. (https://learn.adafruit.com/adafruits-ra ... per-motors)
So I got the following
Small Reduction Stepper Motor - 5VDC 32-Step 1/16 Gearing PRODUCT ID: 858
Adafruit Assembled Pi Cobbler Breakout + Cable for Raspberry Pi PRODUCT ID: 914
Dual H-Bridge Motor Driver for DC or Steppers - 600mA - L293D PRODUCT ID: 807
ULN2803: 8 Channel Darlington Driver (Solenoid/Unipolar Stepper) PRODUCT ID: 970
Full sized breadboard PRODUCT ID: 239
Raspberry PI Powered using Amazon Kindle PowerFast Adapter (1.8A 5V)
I have tried the setup using ULN2803 and the setup using L293D. However I do not see the motor respond.
I have no idea if the motor is faulty or the driver chips or the cobbler kit or the breadboard or if i am doing something wrong.
How can I try to figure this out
Stepper motor via Raspi
Re: Stepper motor via Raspi
Look closely. These motors are geared down so they move very slowly. If you attach a piece of tape to the shaft, it will be easier to see if it is turning.I do not see the motor respond.
Also, check to see if there is any noise or vibration coming from the motor. These motors are generally pretty quiet, but you should be able to feel some vibration as the coils are being energized.
- Franklin97355
Could you post clear pictures of your board and the connections to it?
- greenman
I had attached a paper to the motor to notice any movement.
Sorry if the pictures are not clear. this is the best i could do.
- D7K_1135.JPG (168.38 KiB) Viewed 777 times
- D7K_1134.JPG (171 KiB) Viewed 777 times
Please answer the question.
Also: you mentiond both ULN2803 and L293D. Which one is shown in the photos?Also, check to see if there is any noise or vibration coming from the motor. These motors are generally pretty quiet, but you should be able to feel some vibration as the coils are being energized.
- greenman
this is the L293D
And show us how you have the cobbler connected to the RasPi.Also, check to see if there is any noise or vibration coming from the motor. These motors are generally pretty quiet, but you should be able to feel some vibration as the coils are being energized.
- greenman
I held the motor in hand and sensed no vibrations or noise.
- PI is connected to the wifi dongle via a external powered USB hub. PI itself is powered by the Amazon Kindle fast charger (1.8A and 5V)
- D7K_1139.JPG (192.58 KiB) Viewed 768 times
- Cobbler to PI connection
- D7K_1138.JPG (185.09 KiB) Viewed 768 times
Your ribbon cable is backwards. The white stripe should align with pin 1 nearest the SD card on the Pi.
- greenman
That was it. Thank you very much.
- greenman
Hi
The motor is Small Reduction Stepper Motor - 5VDC 32-Step 1/16 Gearing
which means 512 steps should make the wheel complete 1 turn (360 degrees) right?
In the stepper.py I am having to provide delay ms as 5 and forward steps as 128 to complete 360 degrees not 512.
Am I doing the math incorrectly.
Can you post the code you are using? We have seen some variation in gearing in these from the manufacturer. I may have to tear another one apart to see what is inside.
http://forums.adafruit.com/viewtopic.ph ... 8&p=210326
I just bought 10 of these stepper motors from adafruit and they're all 128 steps, not 512 steps as advertised! should i return them or can you just send out 512 step replacements?
- Franklin97355
Could you post the code you are using to test them? Thanks.
If you're using the tutorial code that defines a 'step' as a complete cycle of:
coil activations, you'll only get 128 of those from a 512-step motor.
Each coil activation above moves the rotor to a position called a 'detente', and the 512-step motors should have 512 detente positons per rotation.
The sequence of activations above is one of the smallest repeatable patterns for driving a stepper motor, and executing all four in a single routine makes the code easier because you can run the same pattern every time. Calling that pattern a 'step' sacrifices accuracy for convenience though.
aL aR bL bR
{ HI, LO, LO, LO }
{ LO, LO, HI, LO }
{ LO, HI, LO, LO }
{ LO, LO, LO, HI }
