I installed Adafruit CC3000 WiFi Shield with uFL Connector for Ext Antenna on an arduino.
Then checked operation with the BUILDTEST script from the Adafruit LEARN site.
I was able to connect to the local network, but when the script reached REQUEST DHCP, it was unable to proceed.
I'm a network newbie, so any insights would be appreciated.
CC3300 hangs on REQUEST DHCP
Re: CC3300 hangs on REQUEST DHCP
What output do you get in the Serial Monitor when you run the buildtest sketch?
Here is the output from the serial monitor when running buildtest:
Hello, CC3000!
RX Buffer : 131 bytes
TX Buffer : 131 bytes
Free RAM: 1263
Initialising the CC3000 ...
Firmware V. : 1.24
MAC Address : 0x08 0x00 0x28 0x57 0xCB 0xB0
Networks found: 3
SSID Name : myNet
RSSI : 52
Security Mode: 3
SSID Name : myNet Guest
RSSI : 52
Security Mode: 3
SSID Name : myNet Sec
RSSI : 43
Security Mode: 3
Deleting old connection profiles
Attempting to connect to myNet
Connected!
Request DHCP
The program hangs at this point.
Hello, CC3000!
Free RAM: 1263
Firmware V. : 1.24
Networks found: 3
SSID Name : myNet
RSSI : 52
Security Mode: 3
RSSI : 52
Security Mode: 3
RSSI : 43
Security Mode: 3
Connected!
Request DHCP
Let's take a look at the hardware too. Please post a photo of your shield, ideally with enough detail that we can check out the solder joints and make sure there none of the components squirmed out of place in the reflow oven.
- Franklin97355
Did you solder the headers on to the shield before testing? can't really tell from that photo.
Yes, headers soldered on prior to testing.
Solder joints checked out OK with DMM and microscope
- prabhag
Exact same problem here... hangs at "Request DHCP".
All connections seems good..
Attaching the front & back image of the shield.
Hello, CC3000!
Free RAM: 1229
Firmware V. : 1.24
MAC Address : 0x08 0x09 0x21 0x51 0xA3 0x1A
Networks found: 7
SSID Name : BinaryStar24
RSSI : 83
Security Mode: 3
SSID Name : DIRECT-NR-VIZIOTV
RSSI : 44
Security Mode: 3
SSID Name : PeachDeer
RSSI : 51
Security Mode: 3
SSID Name : NETGEAR87
RSSI : 51
Security Mode: 3
SSID Name : 2WIRE345
RSSI : 41
Security Mode: 3
SSID Name : ATTjY6nCmS
RSSI : 34
Security Mode: 3
SSID Name : 2WIRE237
RSSI : 40
Security Mode: 3
Attempting to connect to BinaryStar24
Connected!
Request DHCP
- Franklin97355
We have had a lot of problems from people trying to power the arduino and shield from a laptop or through a non powered hub Try using a power supply or a powered USB hub.
- prabhag
External power supply did not help.
Restarted my router and ...
Thanks everyone! :-)
Request DHCP
IP Addr: 192.168.1.121
Netmask: 255.255.255.0
Gateway: 192.168.1.1
DHCPsrv: 192.168.1.1
DNSserv: xx.xx.xx.xx
www.adafruit.com -> 207.58.139.247
Pinging 207.58.139.247...5 replies
Ping successful!
