I am trying to get a reading from an Adafruit ADS1015 breakout. I have followed the tutorial, and hooked up the board as illustrated there to an Arduino Micro. I'll show a picture of the hookup below (I am using 3.3V for the power buses on the breadboard). I am trying to get a reading from an FSR, but so far I only get a consistent result of '4095' result back from any of the ADC pins, using the singleended code example. I have tried different variations of gain (2/3x, 1x, 2x), and different pull-down resistors in the voltage divider (currently 1 KOhm). They have all still left me with the same unchanging reading.
If anyone would be able to help me understand how to continue troubleshooting this problem, I would appreciate it! Can I tell for certain, given the readings I'm getting, that the board is still operational?
Thanks for your assistance!
Note: the ADS1015 is powered by a pair of jumpers hidden under the board, and connected to the rails.
Problem getting a reading from an ADS1015
Re: Problem getting a reading from an ADS1015
You need to have VDD and GND connections to power the ADS1015.
- ekeen3
Thanks for the reply! I wrote in the note that the breakout is connected to VCC and GND by a pair of jumpers hidden under the board, and connected to the rails. It has power, but the connections are just hidden in the photo.
What happens if you connect the input pins to GND?
- ekeen3
With the input pins connected directly to GND, I get the same consistent result of '4095' back from all of the ADC pins, using the singleended code example.
Not sure what would cause that. Let's try replacing the board. Please contact [email protected] with a link to this thread and we'll get one out to you.
- mike6440
I am having this problem exactly. Vdd=5. Addr is at ground. A0=0--3 v. Output is 4095. I am using the code provided.
@mike6440 - please post a photo showing your soldering and connections.
