when I compile thermo.ino I get the following error message :
In file included from helloworld_with_Eink.ino:9:
C:\Users\fadrangi\Documents\Arduino\libraries\EPD_GFX/EPD_GFX.h: In constructor 'EPD_GFX::EPD_GFX(EPD_Class&, S5813A_Class&)':
C:\Users\fadrangi\Documents\Arduino\libraries\EPD_GFX/EPD_GFX.h:48: error: no matching function for call to 'Adafruit_GFX::Adafruit_GFX(const int&, const int&)'
C:\Program Files (x86)\Arduino\libraries\Robot_Control/Adafruit_GFX.h:41: note: candidates are: Adafruit_GFX::Adafruit_GFX()
C:\Program Files (x86)\Arduino\libraries\Robot_Control/Adafruit_GFX.h:41: note: Adafruit_GFX::Adafruit_GFX(const Adafruit_GFX&)
helloworld_with_Eink.ino: In function 'void messageCallout(String)':
helloworld_with_Eink:278: error: 'G_EPD' was not declared in this scope
Any thoughts / advice?
compilation error form thermo.ino
- Franklin97355
Re: compilation error form thermo.ino
The Arduino core libraries has an included ROBOT CONTROL library that conflicts with the Adafruit GFX library. You need to go into the Arduino libraries folder (not the one where your sketches are) and remove the robot control library, don't just rename it, that does not work. Try after you've done that and restarted the IDE.
thanks a bunch Frank. I removed robot librarites from the main folder. But, now I get the following error messages ::
In file included from thermo.ino:37:
C:\Users\fadrangi\Documents\Arduino\libraries\EPD_GFX/EPD_GFX.h:24: error: expected class-name before '{' token
C:\Users\fadrangi\Documents\Arduino\libraries\EPD_GFX/EPD_GFX.h:47: error: class 'EPD_GFX' does not have any field named 'Adafruit_GFX'
thermo.ino: In function 'void loop()':
thermo:179: error: 'class EPD_GFX' has no member named 'height'
thermo:180: error: 'class EPD_GFX' has no member named 'width'
thermo:182: error: 'class EPD_GFX' has no member named 'drawRect'
thermo:183: error: 'class EPD_GFX' has no member named 'drawRect'
thermo:185: error: 'class EPD_GFX' has no member named 'fillTriangle'
thermo:186: error: 'class EPD_GFX' has no member named 'fillTriangle'
thermo:194: error: 'class EPD_GFX' has no member named 'drawChar'
thermo:198: error: 'class EPD_GFX' has no member named 'drawCircle'
thermo:218: error: 'class EPD_GFX' has no member named 'fillRect'
thermo:219: error: 'class EPD_GFX' has no member named 'fillRect'
thermo:227: error: 'class EPD_GFX' has no member named 'drawCircle'
thermo:231: error: 'class EPD_GFX' has no member named 'drawLine'
thermo:232: error: 'class EPD_GFX' has no member named 'drawLine'
thermo:233: error: 'class EPD_GFX' has no member named 'drawLine'
Any thoughts?
Any thoughts?
- Franklin97355
That looks like the libraries are corrupt or missing. Try replacing the Adafruit_GFX and EPD_GFX libraries and see what happens.
