Issues with small 32x32 panel
darbyb
Post by darbyb »
Hi there!
I've been playing around with your 32x32 display, and having trouble getting colours properly defined.
based on your library matrix.fillRect(0, 0, 32, 16, matrix.Color333(7, 7, 0)); should fill the display with yellow, but is instead showing only red.
I've found that using (1, 0, 7) gets me a rough mix of colours, but its clear that quite a few of the pixels are not displaying anywhere near as much brightness. Blue seems to work well, red is super strong, and green kind of all over the place. I am also totally unable to display white pixels, as (7, 7, 7) just shows red
Thinking that this might just be a voltage issue, i've also experimented with making small filled rectangles and circles, and getting the same issues.
is this a case of the display being a dud from the manufacturer? or some other issue. If its a manufacturers issue, is there are chance to get the display swapped?
below is a copy of the test code im playing with, and I'd post a photo, but its proving to be really hard to get a photo that actually shows the brightness issues with the panel
#include <Adafruit_GFX.h>   // Core graphics library
#include <RGBmatrixPanel.h> // Hardware-specific library
// If your 32x32 matrix has the SINGLE HEADER input,
// use this pinout:
#define CLK 11  // MUST be on PORTB!
#define OE  9
#define LAT 10
#define A   A0
#define B   A1
#define C   A2
#define D   A3
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false);
// define some bitmaps
namespace pacman {
const uint16_t Y = matrix.Color333(0, 7, 0);
const uint16_t C = matrix.Color333(0, 0, 7);
const uint16_t chomp[32 * 32] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, Y, 0, 0, 0, 0, 0, Y, Y, Y, Y, Y, 0, 0, 0, 0, 0, Y, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, Y, Y, Y, Y, Y, Y, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, Y, Y, Y, 0, 0, 0, Y, Y, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, Y, Y, Y, 0, 0, 0, 0, 0, 0, 0, Y, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, Y, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, Y, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, Y, Y, Y, 0, 0, Y, Y, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Y, Y, 0, 0, Y, Y, Y, 0, 0, 0,
0, 0, 0, 0, C, C, C, 0, 0, 0, C, C, C, 0, 0, 0, 0, 0, 0, C, C, C, 0, 0, C, C, 0, 0, 0, 0, 0, 0,
0, 0, 0, C, C, C, C, 0, 0, C, C, 0, 0, C, 0, 0, 0, 0, C, C, 0, 0, C, 0, C, C, 0, 0, 0, 0, 0, 0,
0, 0, C, C, C, C, C, 0, 0, C, C, 0, 0, C, 0, C, C, 0, C, C, 0, 0, C, 0, C, C, 0, 0, C, 0, 0, 0,
0, 0, 0, 0, C, C, C, 0, 0, C, C, 0, 0, C, 0, C, C, 0, 0, 0, 0, 0, C, 0, C, C, 0, C, C, 0, 0, 0,
0, 0, 0, 0, C, C, C, 0, 0, C, C, 0, 0, C, 0, 0, 0, 0, 0, 0, C, C, C, 0, C, C, C, C, C, 0, 0, 0,
0, 0, 0, 0, C, C, C, 0, 0, C, C, 0, 0, C, 0, C, C, 0, 0, C, C, 0, 0, 0, 0, 0, 0, C, C, 0, 0, 0,
0, 0, 0, 0, C, C, C, 0, 0, C, C, 0, 0, C, 0, C, C, 0, C, C, 0, 0, 0, 0, 0, 0, 0, C, C, 0, 0, 0,
0, 0, 0, 0, C, C, C, 0, 0, C, C, 0, 0, C, 0, 0, 0, 0, C, C, 0, 0, 0, 0, 0, 0, 0, C, C, 0, 0, 0,
0, 0, 0, C, C, C, C, C, 0, 0, C, C, C, 0, 0, 0, 0, 0, 0, C, C, C, C, 0, 0, 0, 0, C, C, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
  matrix.begin();
  matrix.fillScreen(0);
  // draw the bitmap
  for (uint8_t y = 0; y < 32; ++y) {
    for (uint8_t x = 0; x < 32; ++x) {
      matrix.drawPixel(x, y, pacman::chomp[y * 32 + x]);
  // nothing
adafruit_support_rick
Re: Issues with small 32x32 panel
That sounds very strange. What do the example sketches do? The same sort of thing, or do they display properly?
Franklin97355
Post by Franklin97355 »
Could you post clear pictures of your board and the connections to it? Also how are you powering the matrix?
pburgess
Post by pburgess »
Arduino Uno or Mega? If Uno, almost certainly a RAM limitation...I'll elaborate further (it's a lengthy explanation) if it's the Uno case.
darbyb
Post by darbyb »
It's a mega
howard123
Post by howard123 »
it sounds like your external power supply is not connected or is bad.
pburgess
Post by pburgess »
Do the example programs work? Can you post a photo of the display with one of the examples (e.g. the colorwheel demo) running?
