piTFT help
- Michael_Lewis
piTFT help
After a fun afternoon of setting up the PiTFT 2.8 inch touchscreen AND getting it to run with the cupcade os it suddenly didnt boot properly. it would go to a blank white screen and i discovered that the pi isnt loading Kernel module snd_pcm_oss. i have checked and re-checked everything and looked through the guides and support and discovered through trial and error that the problem wasnt originated from the pi or the SD card but from the piTFT. I'd like to get this running again so i can continue building this project. Thank you in advance.
- adafruit_support_rick
Re: piTFT help
Please post clear, detailed pictures of both sides of the PiTFT, showing your soldering.
- Michael_Lewis
Re: piTFT help
It came pre-assembled but here are the photos
- photo 2.JPG (941.76 KiB) Viewed 908 times
- photo 1.JPG (819.87 KiB) Viewed 908 times
Re: piTFT help
Ah! Well, that's ok then.Michael_Lewis wrote:It came pre-assembled
Are you using the pre-configured Raspbian image from the tutorial? Can you try generating that again? Seems like it must have gotten corrupted.
- Michael_Lewis
Re: piTFT help
im using two different Os.
the cupcade with nes support and the raspbian with touch screen support. both of which are pre-configured. Could it be a SD card problem?
- Michael_Lewis
Re: piTFT help
I did some testing and troubleshooting and the screen just inst being recognized. the kernel module for the cupcade (snd_pcm_oss) isnt loading it just stops. I can exit the shell and login with pi, raspberry just fine but the screen is solid white.
Re: piTFT help
Try re-seating the flex cable in the connector on the bottom of the PCB.. pull the two black tabs at the ends outward, adjust the cable, then press them back in.
FPC connections require spot-on alignment, and it's easy for one to go slightly askew.
- Michael_Lewis
Re: piTFT help
I tried re-seating the cable and it is in as far as it will go, as straight as possible and i still get a solid white screen when i boot up.
Re: piTFT help
Well, it was worth a try.
What information do you find in `dmesg` toward the end when it configures the TFT driver?
- Michael_Lewis
Re: piTFT help
The last thing it shows is loading kernel module snd_pcm_oss then it just stops.
Re: piTFT help
snd_pcm_oss is an module for the ALSA audio system, which isn't related to the PiTFT.
What tests have you done that lead you to think the problem is with the TFT?
- Michael_Lewis
Re: piTFT help
I have been able to press Alt + F3 and exit the shell and login with pi, raspberry. On the guides for the touchscreens it says that if the screen is solid white and doesnt change that for 30 seconds, connect a keyboard and login. if you can, then your pi and sd card is fine, the touchscreen isn't.
Re: piTFT help
That's a fairly general test. Being able to log in is proof that the SD card works, but doesn't necessarily prove there's a problem with the PiTFT. In this case, it sounds like you're hitting a problem with the audio system between the point where the SD card boots the system and the TFT gets initialized.
Log in with the keboard, enter `dmesg` and post the results here please (between CODE tags). I'd like to see what the OS is doing around the time of the last good operation.
- Michael_Lewis
Re: piTFT help
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.32+ (xobs@crash-novena) (gcc version 4.6.3 (Debian 4.6.3-14) ) #3 PREEMPT Fri Feb 28 01:41:33 SGT 2014
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 16 MiB at 1e000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 126976
[ 0.000000] free_area_init_node: node 0, pgdat c05a908c, node_mem_map c0655000
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 126976 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125984
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708.boardrev=0xe bcm2708.serial=0xf50d06b4 smsc95xx.macaddr=B8:27:EB:0D:06:B4 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1fa00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:VGA8x8
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 496MB = 496MB total
[ 0.000000] Memory: 480580k/480580k available, 27324k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdf800000 - 0xff000000 ( 504 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdf000000 ( 496 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc054b6e4 (5390 kB)
[ 0.000000] .init : 0xc054c000 - 0xc056dae4 ( 135 kB)
[ 0.000000] .data : 0xc056e000 - 0xc05a9960 ( 239 kB)
[ 0.000000] .bss : 0xc05a9960 - 0xc06541b0 ( 683 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:458
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001139] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001202] pid_max: default: 32768 minimum: 301
[ 0.001727] Mount-cache hash table entries: 512
[ 0.002534] Initializing cgroup subsys devices
[ 0.002597] Initializing cgroup subsys freezer
[ 0.002632] Initializing cgroup subsys blkio
[ 0.002791] CPU: Testing write buffer coherency: ok
[ 0.003253] Setting up static identity map for 0xc03e5c28 - 0xc03e5c84
[ 0.004864] devtmpfs: initialized
[ 0.028061] NET: Registered protocol family 16
[ 0.034047] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.035141] bcm2708.uart_clock = 0
[ 0.036530] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.036588] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.036625] mailbox: Broadcom VideoCore Mailbox driver
[ 0.036719] bcm2708_vcio: mailbox at f200b880
[ 0.036818] bcm_power: Broadcom power driver
[ 0.036855] bcm_power_open() -> 0
[ 0.036880] bcm_power_request(0, 8)
[ 0.537570] bcm_mailbox_read -> 00000080, 0
[ 0.537613] bcm_power_request -> 0
[ 0.537641] Serial: AMBA PL011 UART driver
[ 0.537780] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.867910] console [ttyAMA0] enabled
[ 0.892594] bio: create slab <bio-0> at 0
[ 0.898074] SCSI subsystem initialized
[ 0.902156] usbcore: registered new interface driver usbfs
[ 0.907736] usbcore: registered new interface driver hub
[ 0.913388] usbcore: registered new device driver usb
[ 0.919900] Switching to clocksource stc
[ 0.924275] FS-Cache: Loaded
[ 0.927442] CacheFiles: Loaded
[ 0.942789] NET: Registered protocol family 2
[ 0.948199] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.955466] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.961992] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.968462] TCP: reno registered
[ 0.971720] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.977627] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.984358] NET: Registered protocol family 1
[ 0.989304] RPC: Registered named UNIX socket transport module.
[ 0.995368] RPC: Registered udp transport module.
[ 1.000094] RPC: Registered tcp transport module.
[ 1.004843] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.012014] bcm2708_dma: DMA manager at f2007000
[ 1.016801] bcm2708_gpio: bcm2708_gpio_probe c057bd30
[ 1.022275] vc-mem: phys_addr:0x00000000 mem_base=0x1fa00000 mem_size:0x20000000(512 MiB)
[ 1.031570] audit: initializing netlink socket (disabled)
[ 1.037192] type=2000 audit(0.880:1): initialized
[ 1.200729] VFS: Disk quotas dquot_6.5.2
[ 1.205085] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.213796] FS-Cache: Netfs 'nfs' registered for caching
[ 1.220497] NFS: Registering the id_resolver key type
[ 1.225804] Key type id_resolver registered
[ 1.230014] Key type id_legacy registered
[ 1.234410] msgmni has been set to 970
[ 1.240771] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.248701] io scheduler noop registered
[ 1.252664] io scheduler deadline registered (default)
[ 1.258236] io scheduler cfq registered
[ 1.263546] BCM2708FB: allocated DMA memory 5e400000
[ 1.268667] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.308892] Console: switching to colour frame buffer device 240x135
[ 1.331379] kgdb: Registered I/O driver kgdboc.
[ 1.336723] vc-cma: Videocore CMA driver
[ 1.340720] vc-cma: vc_cma_base = 0x00000000
[ 1.345533] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.350995] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.365854] brd: module loaded
[ 1.374357] loop: module loaded
[ 1.377828] vchiq: vchiq_init_state: slot_zero = 0xde000000, is_master = 0
[ 1.385867] Loading iSCSI transport class v2.0-870.
[ 1.391762] usbcore: registered new interface driver ax88179_178a
[ 1.398184] usbcore: registered new interface driver smsc95xx
[ 1.404107] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.610189] Core Release: 2.80a
[ 1.613405] Setting default values for core params
[ 1.618369] Finished setting default values for core params
[ 1.824086] Using Buffer DMA mode
[ 1.827461] Periodic Transfer Interrupt Enhancement - disabled
[ 1.833351] Multiprocessor Interrupt Enhancement - disabled
[ 1.839009] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.843421] Dedicated Tx FIFOs mode
[ 1.847604] dwc_otg: Microframe scheduler enabled
[ 1.847861] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.852863] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.860285] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.865905] Init: Port Power? op_state=1
[ 1.869880] Init: Power Port (0)
[ 1.873290] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.880280] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.887626] usb usb1: Product: DWC OTG Controller
[ 1.892394] usb usb1: Manufacturer: Linux 3.10.32+ dwc_otg_hcd
[ 1.898324] usb usb1: SerialNumber: bcm2708_usb
[ 1.903726] hub 1-0:1.0: USB hub found
[ 1.907649] hub 1-0:1.0: 1 port detected
[ 1.911984] dwc_otg: FIQ enabled
[ 1.912004] dwc_otg: NAK holdoff enabled
[ 1.912013] dwc_otg: FIQ split fix enabled
[ 1.912032] Module dwc_common_port init
[ 1.912518] usbcore: registered new interface driver usb-storage
[ 1.919060] mousedev: PS/2 mouse device common for all mice
[ 1.925416] bcm2835-cpufreq: min=700000 max=900000 cur=700000
[ 1.931324] bcm2835-cpufreq: switching to governor powersave
[ 1.937094] bcm2835-cpufreq: switching to governor powersave
[ 1.942834] cpuidle: using governor ladder
[ 1.947015] cpuidle: using governor menu
[ 1.951051] sdhci: Secure Digital Host Controller Interface driver
[ 1.957335] sdhci: Copyright(c) Pierre Ossman
[ 1.961820] sdhci: Enable low-latency mode
[ 2.004073] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.012161] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.018325] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.026312] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.039276] usbcore: registered new interface driver usbhid
[ 2.045058] usbhid: USB HID core driver
[ 2.053666] TCP: cubic registered
[ 2.059178] Initializing XFRM netlink socket
[ 2.065652] NET: Registered protocol family 17
[ 2.070423] Key type dns_resolver registered
[ 2.078517] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.090425] registered taskstats version 1
[ 2.095676] Waiting for root device /dev/mmcblk0p2...
[ 2.104133] Indeed it is in host mode hprt0 = 00021501
[ 2.124541] mmc0: new high speed SDHC card at address b368
[ 2.144237] mmcblk0: mmc0:b368 AF SD 3.84 GiB
[ 2.150183] mmcblk0: p1 p2
[ 2.221025] EXT4-fs (mmcblk0p2): recovery complete
[ 2.226067] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.234353] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.241484] devtmpfs: mounted
[ 2.245151] Freeing unused kernel memory: 132K (c054c000 - c056d000)
[ 2.304100] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.311403] Indeed it is in host mode hprt0 = 00001101
[ 2.514886] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.521755] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.531298] hub 1-1:1.0: USB hub found
[ 2.535773] hub 1-1:1.0: 3 ports detected
[ 2.814341] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.934949] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.941979] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.961866] smsc95xx v1.0.4
[ 3.029265] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:0d:06:b4
[ 3.754285] udevd[155]: starting version 175
[ 11.217779] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 11.681464] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.556811] bcm2708_spi bcm2708_spi.0: DMA channel 4 at address 0xf2007400 with irq 20
[ 12.566078] bcm2708_spi bcm2708_spi.0: DMA channel 5 at address 0xf2007500 with irq 21
[ 12.583255] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 12.596534] bcm2708_spi bcm2708_spi.0: SPI Controller running in dma mode
[ 12.764519] fbtft_device: SPI devices registered:
[ 12.778068] fbtft_device: 'fb' Platform devices registered:
[ 12.789860] fbtft_device: bcm2708_fb id=-1 pdata? no
[ 12.874725] stmpe-spi spi0.1: stmpe610 detected, chip id: 0x811
[ 12.905729] gpiochip_find_base: cannot find free range
[ 12.932803] gpiochip_add: gpios -1..4 (stmpe) failed to register
[ 12.946040] stmpe-gpio stmpe-gpio.0: unable to add gpiochip: -28
[ 12.958605] stmpe-gpio: probe of stmpe-gpio.0 failed with error -28
[ 12.984383] fbtft_device: GPIOS used by 'adafruitts':
[ 12.998729] fbtft_device: 'dc' = GPIO25
[ 13.024077] fbtft_device: SPI devices registered:
[ 13.039857] fbtft_device: stmpe610 spi0.1 500kHz 8 bits mode=0x00
[ 13.052501] fbtft_device: fb_ili9340 spi0.0 80000kHz 8 bits mode=0x00
[ 13.085533] input: stmpe-ts as /devices/platform/bcm2708_spi.0/spi_master/spi0/spi0.1/stmpe-ts.0/input/input0
[ 13.727804] graphics fb1: fb_ili9340 frame buffer, 240x320, 150 KiB video memory, 4 KiB DMA buffer memory, fps=100, spi0.0 at 80 MHz
[ 15.514278] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
[ 15.654508] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2107
[ 15.673473] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 15.697681] usb 1-1.3: Product: Dell USB Entry Keyboard
[ 15.714598] usb 1-1.3: Manufacturer: DELL
[ 15.749923] input: DELL Dell USB Entry Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input1
[ 15.809617] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL Dell USB Entry Keyboard] on usb-bcm2708_usb-1.3/input0
[ 18.794292] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 21.821391] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 24.846344] bcm2835-cpufreq: switching to governor ondemand
[ 24.846382] bcm2835-cpufreq: switching to governor ondemand
[ 27.628822] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 115.886261] usb 1-1.2: new full-speed USB device number 5 using dwc_otg
[ 115.998977] usb 1-1.2: New USB device found, idVendor=045e, idProduct=074f
[ 115.999020] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 115.999038] usb 1-1.2: Product: Microsoft\xffffffc2\xffffffae\xffffffae 2.4GHz Transceiver v5.0
[ 115.999054] usb 1-1.2: Manufacturer: Microsoft
[ 116.040616] input: Microsoft Microsoft\xffffffc2\xffffffae\xffffffae 2.4GHz Transceiver v5.0 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input2
[ 116.041468] hid-generic 0003:045E:074F.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft\xffffffc2\xffffffae\xffffffae 2.4GHz Transceiver v5.0] on usb-bcm2708_usb-1.2/input0
Re: piTFT help
Thank you.. this is the part I needed:
The 'cannot find free range' error usually indicates a problem loading the GPIO kernel driver. That's odd if the whole thing worked and then stopped, but it's possible something got messed up in the system configuration.
What output do you get from `sudo lsmod | grep gpio`?
