Is this for to mate with FPC 0.5mm pitch connector on the RA8875 Driver board? This 7.8" long cable seems to be too long for 9Mhz pixel clock which drives the RGB interface display. Had anyone used it before and had good result?
I want to buy the RA8875 board to drive a 2.4" RGB LCD display (ER-TFT024-3) -- Adafruit's 4.3" is too large for our project. This 2.4" display has 50-pin and we will make short jumper wires connecting the display's flex pins to the 40pin extension.
Regards,
Brian
40-pin FPC Extension Board + 200mm Cable
- Franklin97355
Re: 40-pin FPC Extension Board + 200mm Cable
According to the product page
If you are adding anything to the cable you are on your own as that is not it's intended use.Works great with our 40pin TFTs!
