The backpack has this number on the back: HT16K33
I'm driving my two (4-digit, 7-segment) displays via an I2C bus. Everything works fine, but my question is this: is there code that will turn off the display? I want my project to display data in some modes and not in others, so how do I turn off the display in software?
Thank you!
0.56" 4-digit 7-segment LED backpack
- adafruit_support_rick
Re: 0.56" 4-digit 7-segment LED backpack
You don't turn it off - you just write blanks to the display. I don't have one in front of me right now, so I can't test this, but you can try
You can also try
You can also try
matrix.println();
for (int i = 0; i < 4; i++)
matrix.print(' ');
for (int i = 0; i <= 4; i++)
matrix.writeDigitRaw(i, 0);
- billf
Rick,
thank you very much for the answer. I used your code for my application and it works very well! Here is the code I used - modified for my project.
matrixGreen.writeDigitRaw(i, 0);
matrixYellow.writeDigitRaw(i, 0);
matrixGreen.writeDisplay();
matrixYellow.writeDisplay();
