Unable to access Arduino plus Adafruit CC3000 shield from we
jainraje
Post by jainraje »
HI All,
My HW configuration is Arduino UNO Rev 3 w/ Adafruit CC3000 shield.
All Adafruit CC3000 examples sketches are successfully working with the exception of the HTTPServer.
Here is serial log:
Hello, CC3000!
Free RAM: 795
Initializing...
Attempting to connect to calypso-gu
Connected!
Request DHCP
IP Addr: 192.168.1.9
Netmask: 255.255.255.0
Gateway: 192.168.1.1
DHCPsrv: 192.168.1.1
DNSserv: 192.168.1.1
NOTE: This sketch may cause problems with other sketches
since the .disconnect() function is never called, so the
AP may refuse connection requests from the CC3000 until a
timeout period passes. This is normal behaviour since
there isn't an obvious moment to disconnect with a server.
Listening for connections...
My web browser (http://192.168.1.9) is unable to connect to the Arduino. My trouble shooting has concluded the "website" (192.168.1.9) is online but isn't responding to connection attempts.
Could someone please help and/or advise what I am missing or need to change to get this working.
I can provide further details, screenshots, etc if any questions or more information is required.
Thank you very much.
Rajeev
jainraje
Re: Unable to access Arduino plus Adafruit CC3000 shield fro
Post by jainraje »
HI All,
I was able to get it to partially work by using using a browser on wireless device (iphone) and attaching to same SSID as the Arduino.
Hello, CC3000!
Free RAM: 789
Initializing...
Connected!
Request DHCP
Client connected.
Processing request
Action: GET
Path: /
Client disconnected
Interestingly a browser on a wired computer on the same IP network is not able to connect to the Arduino HTTPSever.
I need to look at my router settings and may need to adjust.
Thank you,
--Rajeev
Franklin97355
Post by Franklin97355 »
Let's keep this in one thread. Continue this in the post you have in Arduino Shields forum.
Return to “Other Arduino products from Adafruit”
