Pro trinket - broken?
alwayssunny
Post by alwayssunny »
I made a mistake when uploading a program to pto trinket 5V.
I did an upload when in IDE 3v Pro Trinket was selected.
Now the computer does not recognize the trinket.
Can I fix it?
Franklin97355
Re: Pro trinket - broken?
Post by Franklin97355 »
That should not have damaged anything. Have you tried to move the Trinket to a different USB port and push the reset button on it?
alwayssunny
Yes I have, I deleted the driver and installed again, and still the 3v is recognized and the 5v is recognized as Unknown Device.
I rebooted the computer, tried another Arduino IDE, all the same.
adafruit_support_mike
You may have a corrupted bootloder.
The source code for the Pro Trinket bootloader is here: https://github.com/adafruit/Adafruit_Pr ... Bootloader and you can try reprogramming the ATmega328 with that.
pentiger
Post by pentiger »
Thanks. Is there a tutorial for that? I don't have a ftdi cable. Im not sure If it's required.
